03-06-2011, 05:50 PM | #1 |
Upper Ball joint removal
Alright, I'm putting new ball joints and springs in the front of my truck. I've got everything torn down (on one side) except for the upper ball joint. I ground out the top of the rivets, but I'm not sure how to get it out. I can't use the press, and no amount of hammering seems to help. I'm thinking about pulling the whole arm out and putting it in a vise. Any help?
'68 C10 LWB 6.2NA/NP833 3.73's |
03-06-2011, 06:00 PM | #2 |
67-72 parts collector,…
Re: Upper Ball joint removal
Pul the arm off and drill them out.
I usually use a grinder to remove the head. Then just air chisel out the rest of the rivets.
03-06-2011, 06:02 PM | #3 |
ok cool thanks
03-06-2011, 06:42 PM | #4 |
leave the arm on ,grind off the rivet head, and air hammer them out.
Fuzzy |
03-06-2011, 06:45 PM | #5 |
use bigger heavier hammer if you dont have the tools the toolsnobs do
03-06-2011, 07:09 PM | #6 |
I had to grind out the rivets and then move up to a 5 pound sledge. A few good swings and they hit the floor.
1970 C10 LWB (Grandfather's Truck) 5.3 4L60E 2012 Victory Cross Country Touring I'm not wasting money on my truck/bike, I'm helping to rescue the economy one mod at a time. |
03-06-2011, 07:43 PM | #7 |
Thank You
Fuzzy |
03-06-2011, 08:56 PM | #8 |
Alright thank guys, I ended up grinding down the rivets more, then knocking them out with a punch and a hammer.
Now I'm trying to get the lower BJ in. The press I rented from autozone seems to be too small, none of the sleeves are long enough and the whole clamp is too short. None of the other stores had anything bigger.
03-06-2011, 09:12 PM | #9 |
Grandpa in the rustmobile...
I think I used a BFH on my balljoints, I KNOW I didnt use a press..lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
03-06-2011, 09:21 PM | #10 |
good reading if it didn't come with instructions
http://www.ehow.com/how_5598087_use-...int-press.html
03-06-2011, 09:23 PM | #11 |
you got them in that way? That might work if I pulled the LCA out.
03-06-2011, 09:23 PM | #12 |
lol same method I used. BFH and they popped right out. and to put the new ones in they should just be bolted on the top and the bottoms I used the same BFH and they popped in after a few hits. also not a bad idea to use a socket to keep from smashing the center where the grease fitting sits.
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 03-06-2011 at 09:24 PM. |
03-06-2011, 10:06 PM | #13 |
Cruzin
x2
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
03-07-2011, 04:51 PM | #14 |
So when y'all hit the BJ in with a hammer, was the control arm installed?
03-07-2011, 09:14 PM | #15 |
Take the lower control arm off and use a press.
2007 Chevy 2500HD all stock 1985 Chevy Blazer- sold 1971 Chevy c10- The Mistress 2014 Ford Interceptor SUV |
03-07-2011, 09:33 PM | #16 | |
Son of a gun
Put the lower bj in the hole, support from the bottom with a solid wooden block. Beat around the lbj with a BFH until the ball joint is seated. Or go to the auto parts store and get a ball joint press on the "free loaner" program.
Bill BEATERS ARE NEATER |
03-07-2011, 10:00 PM | #17 |
Cruzin
yes i have done it installed and out i try it installed first if ya got enough room to get a good swing under it.
03-08-2011, 10:12 PM | #18 |
Hey y'all, spent a little more time messing with the press and got it figured out. It's all put back together now! The new 3/4 ton springs really help around corners and they don't ride to bad, now for some new shocks. Thanks!
03-05-2014, 07:16 PM | #19 |
Replacing ball joints in a 1967 C10, I ground the heads of the rivets off so they were flat, center punched it and drilled half way through. I than used a chisel to knock off the tops, punched out the rivets. With the bottom a arms I used a rented puller from parts store. However I used my die grinder to cut away the top part of the ball joint, so I could remove the pin. Once that was done the puller was a breeze, good luck everyone.
01-18-2015, 06:06 PM | #20 |
removed mine last night. Just drilled through the top of the rivets enough to be down inside the bj plate. then took a chisel and a bfh and knocked the rest of the caps off. Then 2 smacks with the bfh and the upper bjs went flying across the shop. pretty easy actually. A lot easier than getting the damn bushings out.
