Old 03-07-2011, 09:38 PM   #1
bikernut
bikernut's Avatar
Key removal
I just purchased a 2003 GMC 3500 4x4 dump truck. when I shut it off I can't remove the key from the ignition switch without pushing the shift lever up a bit. It seems like the spring that holds the shift lever up it loose or maybe there is an adjustment to it to keep the lever up in position, it only has to move about a 1/2" up and the key comes out. Is this something that has an adjustment or does something need to be replaced. In either case can you give instructions or is this better off at the dealership? Thanks
2020 GMC Acadia Denali (Maroon)
2003 GMC 3500 4X4 Dually Dump (Red)
2007 KZ 41KG Toy Hauler (White with stripes)
2015 Harley FLHTCUTG Trike ( Maroon)
1995 Harley FLT (2 tone Red)
1992 Chevy S-10 4x4 Blazer (Dark Red)
bikernut is offline   Reply With Quote
Old 03-07-2011, 10:16 PM   #2
Sillyoldman
#16876
Sillyoldman's Avatar
Re: Key removal
I thought that was a Ferd problem. Not sure what the fix is but here's a bump for ya.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 03-07-2011, 10:44 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Key removal
I'd try adjusting the shifter cable before I took it anywhere. I can't tell you where it will be, but there should be a joint in the cable where you can adjust it or one of the ends will be adjustable.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-08-2011, 02:24 PM   #4
bikernut
bikernut's Avatar
Re: Key removal
it seems to me that the cable is adjusted correctly as it is in the right position when shifts thru the gears, it is just a weak spring or something when you put it in park that the lever doesn't go all the way forward, toward the dash to release the key everything else seems okay.
Old 03-08-2011, 07:44 PM   #5
usmcchevy
usmcchevy's Avatar
Re: Key removal
The spring could be bad, but try some lube first. Pull back the shift boot and also at end of the column where the cable attaches.
Build thread
LSx Swap FAQ index
Old 03-08-2011, 11:32 PM   #6
ajcan
ajcan's Avatar
Re: Key removal
bikernut
My 2001 1500 does the same thing.Feels like there should be a spring to hold it up but is missing.I don't know how it works but I would like to know too if someone knows.
AJ
ajcan is offline   Reply With Quote
Old 03-09-2011, 09:21 AM   #7
bikernut
bikernut's Avatar
Re: Key removal
I will try this and see if it works, thanks
