Old 03-07-2011, 10:59 PM   #1
boucher racing
boucher racing's Avatar
single to dual master cylinder- F/R lines?
I just swapped out my single master cylinder for a double and split the lines. I am pleased the way it turned out, but got to thinking. The M/C is for a drum/drum setup, so the front and rear reservoirs are the same size. Does it matter which line goes to Front or Rear? Right now I have the line closest to the firewall going to the rear.
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 03-07-2011, 11:48 PM   #2
jimmydean
jimmydean's Avatar
Re: single to dual master cylinder- F/R lines?
As far as I know it doesn't matter if you are running drum/drum. But you will need a proportioning valve for disc/drum and then it matters what hole on the prop valve you use.
Good looking install.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-12-2011, 06:45 PM   #3
slepysal
slepysal's Avatar
ON mine I used the rear port for the rear brakes and the front port for the front brakes.
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 03-12-2011, 09:18 PM   #4
rideblue00
rideblue00's Avatar
How did you decide what master cylinder to buy? Or what was it from? It looks like it fits well.
rideblue00 is offline   Reply With Quote
Old 03-13-2011, 12:55 AM   #5
Captainfab
60-66 Nut
If you're running drum/drum brakes, get one for a '67-'70 pickup. If you're running disc/drum brakes, get one for a '71-'87 pickup as well as the correct proportioning valve.
Old 03-13-2011, 06:44 AM   #6
rideblue00
rideblue00's Avatar
So i am assuming that 67-70 is the drum/drum still? Because i know some of the 67-72 years had disc brakes. 71-72?
Old 03-13-2011, 03:48 PM   #7
Captainfab
60-66 Nut
Yes, the '67-'70's were only available with drum/drum brakes, Front disc brakes weren't available until '71
Old 02-09-2012, 01:46 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
The master cylinder I pulled off the 1/2 ton 79 suburban had disc/drum, but the front and rear reservoirs are the same size. I thought disc/drum reservoirs were supposed to be different sizes. Beings they are the same size, would I be able to use it on my 65 drum/drum?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-09-2012, 01:53 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
Then someone had the wrong master on the suburban, you can use the disc /drum on a drum/drum if you choose to make a change to disc at a later date.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 02-09-2012, 02:41 PM   #10
LostMy65
LostMy65's Avatar
Here's pics:
Old 02-09-2012, 03:09 PM   #11
losthope
losthope's Avatar
IF YOU GOTO POST #80 ON THIS LINK IM POSTING THAT "CHEIFROCKA" DID ON DUAL MASTER SPLITING LINES ON A DRUM/DRUM HAS A PICTURE SAYING THE RESERVOIR CLOSET TO THE FIRE WALL IS FOR THE FRONT BRAKES!!
http://67-72chevytrucks.com/vboard/s...d.php?t=332148
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 02-09-2012, 03:14 PM   #12
Rich 5150 69
OK I stand corrected....
Old 02-09-2012, 07:07 PM   #13
jocko
jocko's Avatar
Hey, back to the original question - on a drum/drum dual reservoir master cylinder - YES, it DOES matter which reservoir goes to front/rear brakes, and it is less than obvious. The FORWARD reservoir's port (closest to the grille) should be connected to the rear brake line. The aft reservoir's port (closest to the firewall) should be connected to the front brake line. The reason for this is that a dual res drum/drum master does "pseudo" proportioning in the way the ports are uncovered when the master's piston slides forward (when you press the brake pedal). So, it is important - if you do it backwards (as suggested in some of the above posts), you will have pressure to the rear brakes first and potentially lock up the rears only in a panic stop. Not good. This is also why there is no need for a prop valve on a drum/drum setup (yes, a brake pressure transducer can be placed in between the lines, but not a true prop valve on a drum/drum setup).
67 dual drum master is a great sub for the old single master, gives you a much safer system. someone mentioned Chief Rocka's thread above - agree, great thread.
Here's the line split I did a while back:
http://67-72chevytrucks.com/vboard/s...d.php?t=487384
EDIT - Hey, Losthope - I'm sorry, somehow I missed your post - you answered this spot on.
Old 02-10-2012, 12:31 AM   #14
Captainfab
60-66 Nut
I have seen a number of master cylinders on disc/drum trucks that had both reserviors the same size. I think it must have to do with the particular brake option/package that the truck came with. In my experience it has been more common on C20's
Old 02-10-2012, 03:10 AM   #15
LostMy65
LostMy65's Avatar
Thanks,
I'll post it here also.
Originally Posted by ChiefRocka View Post
The REAR PORT, closest to the PUSHROD is the main, or "primary" chamber.
This port is for the FRONT brakes....
The FRONT PORT, furthest from the PUSHROD is the secondary chamber....supplying the REAR brakes.
