Old 03-08-2011, 12:00 AM   #26
DaBigKahuna
DaBigKahuna's Avatar
Re: add air conditioning ? 1972 C10
Thanks Bozo
DaBigKahuna is offline   Reply With Quote
Old 03-17-2012, 11:03 PM   #27
Oldskewl70
Oldskewl70's Avatar
Originally Posted by wwotr View Post
The PO put a 1994 350 from a GMC Sierra into my 72.
Had the OEM Compressor, Woiring Harness, everything.
I had to buy a new Head Unbit, Rebuilt Compressor, (My Cab was already AC).
I had a professional do mine.
Final bill was about $700.00.
I've got same issue with my junk all89 mod stuff my trucks cst so factory air how do I make it work? Why did u bu a new head unit wha did hat have to do with it
Oldskewl70 is offline   Reply With Quote
Old 03-17-2012, 11:14 PM   #28
Oldskewl70
Oldskewl70's Avatar
My 70 is a cst with all 89 compressor , motor wiring and all , can't seem to make ac work anyone know what all needs to be replaced or retro fitted?
Old 08-24-2013, 03:09 PM   #29
67chevy1series
67chevy1series's Avatar
I've been trying to find this but I can't I guess it isn't around. Does anyone have a list or a diagram that shows the 67-72 chevy/gmc AC system? I'm getting closer to AC an I just want to see what I have and what I need to get still. Also any of you that have the Pro6ten compressor Hooke up to the factory AC system, how well does it cool? I it make a difference or does it at least make turning the AC on worth while?
67chevy1series is offline   Reply With Quote
Old 08-24-2013, 08:46 PM   #30
BruthaMan
US Army Veteran
BruthaMan's Avatar
I have the Pro6ten compressor in my 72. It's quiet and smooth, considerably lighter than the A6 and bolts right in.
I'm running ES-12a Industrial (hydrocarbon) for now, and it cools pretty good. A couple threads that may be of help:
http://67-72chevytrucks.com/vboard/s...d.php?t=583056
On the one below, the problem turned out NOT to be the compressor, expansion valve or the POA valve. It was simply the condensor, where the top fitting was, had "crimped" when it was tightened and cause a severe blockage.
I cannot even begin to describe the amount of money and time I spent trying to diagnose that simple problem. It was a brand new condenser, so my "thought process" was not even to focus there, but on everything else.
http://67-72chevytrucks.com/vboard/s...d.php?t=528504
I have a new diverter box for the cab, which I need to put in. For now, I've been working on finishing up my '78 so I can put it up for sale. Then will focus back on my '72.
You might also check my '72 "build thread" in my signature. It's not really a build, just more of tinkering and trying to get things they way they should be. I may have some pics there of where the fan relay was replaced and a few other things AC related.
The steps in that first thread should help you get an idea of what to do. I played it pretty safe. To flush the system, I have an air compressor in my garage. I bought a "spot sandblaster" from Harbor Freight and added acetone (instead of sand, heh!), then hooked up a rubber hose to the nozzle and spray it through the system to flush it. Worked pretty well. The "spot sandblaster" is air powered, all contained unit with a cup where you would normally add sand, hook up to your compressor line. It was the only thing I could find where I could add acetone, then use my compressor to blast it and use a flush.
Be sure to get new o'rings. You can get those just about anywhere. HF has an o'ring kit with all sorts.
If you are going to run R134, you will need to adjust the POA valve. I've covered that in one of the threads above. Ultimately, I should do a fresh write up with pictures of everything. I spent way more than I would have if I had taken it in to be done, BUT...I wanted to learn this stuff. I don't have a lot of faith in relying on others, so I tend to be stubborn about learning things myself. Unfortunately, most of the time, it tends to be the hard way!
BruthaMan is offline   Reply With Quote
Old 08-25-2013, 03:08 AM   #31
67chevy1series
Thank you for the write up!
Old 08-28-2013, 10:52 AM   #32
snipescastle2
snipescastle2's Avatar
Talking Re: add air conditioning ? 1972 C10
When I got my "basket case" I also got a 1970
Parts truck that had factory
Air. My '71 didn't have
Air, so I am adding it
As I go. I'm going to use most
Of the factory system
Except for the compressor
And POA valve, going
To use the late model
Orifice tube system
Within the evaporator
Box, and use a R4 radial
Compressor. I'll have
To make some custom
Hoses, but that's the
Hard part. I made a template
For the firewall to
Mount everything
In the stock location.I can send you a copy
Of the template if you like. Let me know.
Ben Smith
snipescastle2 is offline   Reply With Quote
Old 01-31-2015, 10:49 AM   #33
elf w/capital T
Curious for who used the stock compressor...how did you wire it to the vintage air wires? I have two coming from the stock unit which is from a 92 serpentine setup...
elf w/capital T is offline   Reply With Quote
Old 01-31-2015, 09:13 PM   #34
ss454conv
To Snipecastle2, I would not recommend the orifice tube. Six Pack Bee said it well.
I had one of these in a Chevelle and it was terrible. Ended up removing it and re-installing the POA with adjusted pressure setting and it works much better. If you still wish to use it. let me know and I will sell you mine cheap.
ss454conv is offline   Reply With Quote
Old 02-03-2015, 11:29 AM   #35
snipescastle2
I already have the entire setup, but I'm probably going to run a vintage air unit, just because i just shaved my cowl vents and wanted to clean up the interior. thanks any ways!
Ben
Old 04-24-2015, 06:56 AM   #36
elf w/capital T
Don't forget the bracket for the temperature control assembly mounting to the dash. I went and bought a Vintage air and a Craigslist ac temp control and tried to install...not cool found out there's a bracket!
Old 04-24-2015, 08:20 AM   #37
jjzepplin
jjzepplin's Avatar
I am also very stubborn and will tackle this myself and pay the extra $500. I have two trucks with serpentine systems and have fitted one with the SD5 Sanden. I will use the existing stock A/C with a new parallel condenser. I plan to run a trinary switch to operate a small aux fan on the condenser. I am going to buy a hose kit off ebay and a hose crimper. When I am finished and satisfied I will rent out the crimper to Members for free. Just fixed my wife's A/C in the Yota. Had to pull the whole dash to get to the evaporator. OUCH! Was just clogged with outside air debris. I told her to roll down the window next time she wants some outside air. Thought about removing that cable altogether...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 05-22-2016, 01:09 PM   #38
Jere
Orifice tube system
To make some custom
For the firewall to
Mount everything
Ben Smith
if you could i would like that template
Jere is offline   Reply With Quote
Old 05-22-2016, 03:43 PM   #39
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: add air conditioning ? 1972 C10
I installed a factory looking unit but it has secrets. I swapped everything out for 134 a stuff and used a newer compressor. AC runs at 40* on 90* days here in SC.
I bought the 134 a stuff form Classic air group.
I also deleted the outside fresh air flapper on mine and it works great. I can still get fresh air by the windows are the drivers side kick panel.
Here is the thread I did on my mods a few years back.2002!
http://67-72chevytrucks.com/vboard/s...d.php?t=253275
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-22-2016, 06:21 PM   #40
B. W.
B. W.'s Avatar
Don't want to hijack this thread but I have a question for Andy - do you know what year or have part numbers for the late model evaporator & accumulator that you used? I'm in the process of doing the same thing.
Thanks!
Bobby
B. W. is offline   Reply With Quote
Old 05-22-2016, 08:58 PM   #41
Andy4639
Old member
Andy4639's Avatar
Thanks!
Bobby
That was to long ago to remember part numbers but if you call Original air group and tell them what year you have they will put you with the right stuff I'm sure. They did me anyway.
They put my truck on their catalog last year too!
Old 05-22-2016, 09:30 PM   #42
B. W.
B. W.'s Avatar
Thanks, will do.
