Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-09-2011, 07:53 AM   #1
68C15
blood type; Retumbo
68C15's Avatar
please drain fuel safely
this may end up in shop safety but I think here is a good idea to begin.
it appears some "mechanics" were draining gas from a car into 5 gallon buckets prior to fuel pump replacement. I'm guessing they didn't have them grounded properly (put it on the floor at least).
all it takes is one little spark.
http://keloland.com/NewsDetail6162.cfm?Id=111884
this is why we use a metal 30 gallon barrel and have a wire alligator clipped between it and the car. we also have a seperate battery mounted at least 2 feet above the barrel to run the pump.
68C15 is offline   Reply With Quote
Old 03-11-2011, 02:27 AM   #2
treveiger
treveiger's Avatar
Re: please drain fuel safely
People take advantage of gasoline when it comes to safety seems like anymore. At least no one was killed.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 03-11-2011, 10:33 AM   #3
pat 70/71
pat 70/71's Avatar
I remember reading a news letter from a club i was in SOTO (vw trucks&bus's) I had a single cab truck (61) anywho, letter was about a member who was working on his gas tank feed line to the pump . he pulled the line off&it started to leak gas so he grabbed a hub cap to catch the gas& slid it under the motor it made a spark when it hit the ground and that was it total fire in seconds. he got burned(from the fuel on his hands) this happened in his garage! the truck was also burned up( it was later repaired) the garage had a little damage (just lucky the truck was pushed out of the garage) sorry for the long post. we all can learn from this tragic story. Pat
pat 70/71 is offline   Reply With Quote
