Old 03-09-2011, 05:23 PM   #1
69BB396
69BB396's Avatar
Disc/drop and Tie Rod length problem 69 C10
Drivers side tie rod is too long, when sleeve is fully tightened.
Using original center link, otherwise all new parts checked against old ones.
CPP kit, uses original ball joints, tie rods.
Puzzled....
Here is the link (suspension) with photos I posted
Ron
http://67-72chevytrucks.com/vboard/s...d.php?t=451878
69BB396 is offline   Reply With Quote
Old 03-09-2011, 06:22 PM   #2
cdowns
cdowns's Avatar
Re: Disc/drop and Tie Rod length problem 69 C10
by your pic it looks like you have room to screw eack tirod end further into the sleeve or is it bottoming out? have you tried screwing tirod sleeve further onto the centerlink? have you measured how far the threads go in the sleeve and how much of the tirod end is screwing into it?
Old 03-09-2011, 06:30 PM   #3
69BB396
69BB396's Avatar
Hi
both the inner and outer tie rod are bottoming out. They are turned in as far as they will go. There are threads still showing, both are in full. One has threads turned farther up the shaft. Initially I thought perhaps one was getting hung up internally, so I removed them both and gently cleaned up the threads with a wire wheel.
RW
Old 03-09-2011, 07:41 PM   #4
mmmBoost
I would cut some off the inner part of the tie rod ends shafts to make them shorter
Always remember those that had your back
Never forget those that turned it
Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt,
Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner
mmmBoost is offline   Reply With Quote
Old 03-09-2011, 07:54 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Assume you already called CPP and asked them for technical help...since you have their stuff.
Member Nr. 2770
Old 03-09-2011, 07:56 PM   #6
scrapmetalart
Junior Member
sounds like what I would do as well
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 03-09-2011, 08:57 PM   #7
69BB396
69BB396's Avatar
The disc/drop kit is CPP, the steering parts are NAPA replacement.
Trimm the outers is what I may do, thanks boys
69 396BB Turbo 400 Fleetside, 3:07 Gears
2.5" & 4" drop
2020 Silverado 2500LT
2006 Subaru Forester
2019 Chevy Cruze
Old 03-10-2011, 04:08 PM   #8
69BB396
69BB396's Avatar
I wonder, is it possible that the steering box does not need to be exactly on-center...... If I moved it say, 1/8 or 1/4 turn, this would move the center link over enough to be OK. (it may thow out the passenger side though)?
This would also affect the turning radius side to side, unless the spindles touch the stops before the gearbox reaches its turn limit?
Thoughts?
Ron
2.5" & 4" drop
2019 Chevy Cruze
