03-09-2011, 08:25 PM | #1 |
steering column question
Hi i'm new on here. I have a 66 c/10 daily driver (will be posting pics soon) and the three speed steering column is wearing out. I have access to a 63 column but i heard only 64-68 would work in a 66. Does anyone have any info on this?
03-09-2011, 08:27 PM | #2 |
One foot in front of the other
Re: steering column question
Don't know why it wouldn't
03-09-2011, 08:30 PM | #3 |
Why not rebuild your column? You can get new upper and lower bearings and a new turn signal switch.
03-10-2011, 01:01 AM | #4 |
60-66 Nut
Welcome to the forum
The wiring plug on a '63 column is different than on the '64-'66's. Otherwise it will work.
03-10-2011, 12:31 PM | #5 |
Captn fab is very correct. If you are experiencing the shift lock up issue, then it may need more than just the upper and lower bearing.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
03-10-2011, 07:19 PM | #6 |
Thanks guys. Yeah i can't shift out of first gear when the truck is moving. I decided just to buy a floor shifter. Mr gasket has them fairly cheap
