Old 03-08-2011, 09:24 PM   #1
marty_badbowtie
marty_badbowtie's Avatar
Question how do i know if my truck has a suspension lift on it?
i have a 1989 z71, and im pretty sure it has a 3inch body on it, ands it has 33s on it. is there a chance it could have a suspension lift on it? ive seen some other trucks with suspension lifts and i cant tell if im higher than them, so maybe you guys can help me
marty_badbowtie is offline   Reply With Quote
Old 03-08-2011, 10:49 PM   #2
corbinc
Re: how do i know if my truck has a suspension lift on it?
It certainly has a higher ride than stock. Did you check the springs/shocks/pitman arm for branding?
'91 Chevy K1500 Z71, 5.7l
corbinc is offline   Reply With Quote
Old 03-08-2011, 10:52 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Your frame is really exposed. And I can see the body lift blocks under the bed. Main drawback to a body lift.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-08-2011, 11:58 PM   #4
benoit454
Chris
benoit454's Avatar
it's got a 3 inch body lift for sure but I doubt anything else.
Only way to tell is if it has a block between the rear spring and axle, or an add a leaf, which is harder to tell, but if so it's only 2 inches if that, front torsion bars can be cranked up too, no way to know on that one really unless the bolts are bottomed out.
The blocks being seen is an easy fix, it's called gap gaurds or make your own. Same goes for up front and raising the rear bumper to match.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 03-09-2011, 12:06 AM   #5
Tony_SS
Tony_SS's Avatar
If a 2 or 3" body lift is done, are there any other mods like steering that need to be fixed?
Tony_SS is offline   Reply With Quote
Old 03-09-2011, 12:53 AM   #6
benoit454
Chris
benoit454's Avatar
just a steering shaft extension from what I've seen. it comes in the kit.
Chris
GIT R DONE!!!!!!
Old 03-09-2011, 09:08 PM   #7
marty_badbowtie
yea i thought it was probably just a body lift, thanks for the help guys.
chevy, lifted, mud, offroad, z71
