Old 03-10-2011, 04:29 PM   #1
kikkegek
kikkegek's Avatar
inspection hatch left of right front wheel?
can anybody tell me whats behind this?
the nuts are tight as hell.
kikkegek is offline   Reply With Quote
Old 03-10-2011, 05:10 PM   #2
nerphin
nerphin's Avatar
Re: inspection hatch left of right front wheel?
that is just reinforcement, the inner fender is solid behind it.
nerphin is offline   Reply With Quote
Old 03-10-2011, 05:20 PM   #3
kikkegek
kikkegek's Avatar
why? its only a very small patch, like only 2-3 by 4-5 inch?
Old 03-11-2011, 02:31 AM   #4
nerphin
nerphin's Avatar
the bigger bolts attach to the cab, just for extra support i guess.
you can see both spots below.
Old 03-11-2011, 02:41 AM   #5
kikkegek
kikkegek's Avatar
hmmm..okay...
well maybe you can then tell me how I can access the wires that run from the door through the rubber piece into the car?
I want to install speakers into the door, but cant seem to find how I can acces the wires from inside the car...
Old 03-11-2011, 03:04 AM   #6
tobiahr
tobiahr's Avatar
use the xray goggles that came with the factory service manual.
i believe the wires enter the body cavity just above the dash attachment point from the inside of the cab under the dash. the rest is a PITA
tobiahr is offline   Reply With Quote
Old 03-17-2011, 10:43 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
the thicker spots are the first to go when the inner fender rusts out around here
some ppl will just weld a patch in there when it goes
the speakers (wires are going threw the black tube in pic)
look above the e brake, you will see the elect wires come in, above where the dome light wire is same area both sides
ive used a coat hanger pushing from inside the door and pulling from inside
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-17-2011, 02:05 PM   #8
kikkegek
kikkegek's Avatar
He thanks John,
in the mean time I have managed to get the wires through the door. Ik took the inside panel of the door of. And then used full core electrical wire to push through from inside the door into the cabin. Then connected the soft core speaker wire to it and pulled it through.
thanks man!
