Old 03-10-2011, 08:34 PM   #1
ihatericeburners
ihatericeburners's Avatar
Pitman arm is loose but cant get it off...
I have the pitman arm unbolted and free from the drag link and the steering box shaft, BUT I cant seem to remove the arm. if I angle the arm up, it hits the shaft and wont free the other end for the drag link. there doesnt look to be enough play. This doesnt seem to be normal, Is there some trick?
Thanks,
Tony
ihatericeburners is offline   Reply With Quote
Old 03-10-2011, 08:58 PM   #2
68anniversary
Re: Pitman arm is loose but cant get it off...
If we had a pic of your situation I'm sure we could help you solve this.
68anniversary is offline   Reply With Quote
Old 03-10-2011, 09:11 PM   #3
ihatericeburners
Old 03-10-2011, 09:12 PM   #4
ihatericeburners
got her.
Old 03-10-2011, 09:14 PM   #5
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
There is a special tool to remove the arm.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 03-10-2011, 09:18 PM   #6
ihatericeburners
yes. the arm is unbolted and loose on both ends but i am unable to remove it completely because both ends bind. preventing it from moving up down or side to side.
Old 03-10-2011, 09:24 PM   #7
mstrav1973
mstrav1973's Avatar
turn the wheel all the way to the right to make the arm come towards the picture. should be able to drop once rotated
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 03-10-2011, 09:24 PM   #8
ihatericeburners
and i have to finish tonight and get to work tomarrow.
Old 03-10-2011, 09:43 PM   #9
68anniversary
Or you can loosen the idler arm at the frame and it will drop the drag link so it should be a breeze.
Old 03-10-2011, 10:59 PM   #10
kevmic28
kevmic28's Avatar
Tighten it back up on the power box then use a long screw driver to pop out the other end, then take it back off the box. I did it about a month ago that way. It was still hell to get back on again.
1970 GMC truck
1988 Harley 1200 Sportster
kevmic28 is offline   Reply With Quote
