Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 03-10-2011, 10:07 PM   #1
northerngmc
northerngmc's Avatar
Light Transparent Garage Doors
I am looking into having a garage built this coming spring. I am in the process of researching garage doors. I am looking to put in one 16' X 8' overhead door.
What I have seen in my travels are shop doors that are some what transparent. Not glass panels, but appear to be some sort of composite material that provide security and insulation value, but will let the light through.
I have spent hours on google and many garage door website without much luck. I live in the middle of no where and about 10 hour drive to a decent overhead door company.
Just looking for information and if anyone here might now a manufacturer or has experience with this style of door.
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 03-10-2011, 10:48 PM   #2
bruceman1968
bruceman1968's Avatar
Re: Light Transparent Garage Doors
Is this what your thinking of? http://www.filuma.co.uk/features.html
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-10-2011, 10:54 PM   #3
67HEAVEN
www.67HEAVEN.com
67HEAVEN's Avatar
If you're building in the NWT, wouldn't an insulated overhead door be more practical?
I'll bet the heat loss through those translucent doors is bad.
www.67HEAVEN.com
2004 Z71 Tahoe 4x4 5.3L (factory white monochrome theme)
1989 Silverado K1500 4x4 5.7L sportside (white monochrome theme)
1967 Belair 2-door-post (project)
1967 Corvette 427/435 coupe (now 502/502 red road warrior)
67HEAVEN is offline   Reply With Quote
Old 03-10-2011, 11:51 PM   #4
northerngmc
Originally Posted by bruceman1968 View Post
Yes that is the idea.
Blaine
Old 03-10-2011, 11:52 PM   #5
463
463's Avatar
i'am with 67 Heaven on this one if your heating the shop Blaine. and i know that two doors are better than one big one. on my garage i am useing 2-10' x 8' mod #8300 R14 over head doors since 2003 and the seals on the bottom of the door when the temp is below -10 c as the seal gets so hard that it will not give a seal (you can see light under the door) other than that there a good door. http://www.overheaddoor.com/garage-d.../products.aspx heres a pic
Trueman
463 is offline   Reply With Quote
Old 03-10-2011, 11:55 PM   #6
northerngmc
Yes it needs to have an insulated value.
I have seen them used in industrial shops in cold climates, so they must have some insulated value.
The one posted above looks quite light and probably not insulated.
Blaine
Old 03-11-2011, 12:02 AM   #7
northerngmc
Thanks, yes two small doors might work better for heat, but harder to get an airplane into!
My attached garage has two small doors and this is where the daily drivers sit. I am looking to build a second garage to keep my 68 C20, Farmall H, and sleds and motorbikes. The door won't be going up and down regularly. Maybe one day I will attempt to build an airplane.
Blaine
Old 03-11-2011, 12:17 AM   #8
Shane
Shane's Avatar
http://www.glassgaragedoors.com/gallery.htm
Shane is offline   Reply With Quote
Old 03-11-2011, 12:20 AM   #9
northerngmc
Originally Posted by Shane View Post
Thanks but I am sure the ones I have seen are some sort of a composite material and thicker than glass.
-27 C here right now and it was -33 C this morning. I need insulation!
Blaine
Old 03-11-2011, 12:24 AM   #10
northerngmc
Hummmm wikipedia on garage doors talks about "transparent corrugated fibreglass" .......
Blaine
Old 03-11-2011, 02:46 AM   #11
Frank71
Frank71's Avatar
Take a look at this link..
http://www.sunshinedoor.com/
10 year warranty, triple wall insulation etc..etc.. I am not sure of the cost?
"If you need to tell everyone how good you are - your probably not"
Frank71 is offline   Reply With Quote
Old 03-11-2011, 09:37 AM   #12
Shane
Shane's Avatar
yeah, that's why I posted that ... I would have thought double pane glass is gonna be a much higher R factor than anything made of fiberglass or other type composites ... <shrug>
Old 03-11-2011, 10:40 AM   #13
northerngmc
THANK YOU very much. I think this is the product!
This is probably what I would do, is go half light panels and have solid.
Now to find out the cost!
Blaine
Old 03-12-2011, 02:53 AM   #14
Frank71
Frank71's Avatar
happy to help, good luck.
