Old 03-11-2011, 09:32 AM   #1
softballnrd27
Always a work in progress
softballnrd27's Avatar
Well, Monday should be a great day!!!
My wife should be picking up a 2004 LQ4 w/149k miles for me!! Even though I won't be able to touch for a few more months, it will be there for me when I get home!
My 1st question about it though, what does it take to make it DBC instead of DBW? I know I will need a DBC TB but what else? The motor will come complete from intake to oil pan including alt, and starter for $950. It will not have a tb, comp or harness but that isn't a big deal bc I can get that stuff for relatively cheap. I will not need the AC right now bc that will be later on.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 03-11-2011, 11:20 AM   #2
noonzor
Re: Well, Monday should be a great day!!!
i believe its just the tb and the pedal assembly thatll change, then get a dbc harness? someone correct me if im wrong.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 03-11-2011, 11:31 AM   #3
softballnrd27
I am buying a stand alone harness. Does the intake have provisions for a throttle cable bracket?
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-11-2011, 11:44 AM   #4
noonzor
yes i believe so. theres minor differences between yrs of the truck intake, might just be easiest to swap intakes if thats the case. but theres a ton of threads when i googled dbw to dbc, when you start the conversion i'd suggest doing the same. shouldnt be an issue though its a pretty common swap it seems.
Old 03-11-2011, 12:25 PM   #5
softballnrd27
what did you type? I did that earlier and I hardly got anything back
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-11-2011, 12:28 PM   #6
noonzor
ls dbw to dbc, lots from ls1tech.com which would be another good place to post your question or even scroll through.
Old 03-11-2011, 12:36 PM   #7
softballnrd27
I must have typed in the wrong place on ls1tech
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-11-2011, 02:23 PM   #8
Clyde65
Clyde65's Avatar
I did it and just changed out the intake and Tb together, locar 36" cable and your good to go.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-11-2011, 05:21 PM   #9
softballnrd27
My next issue is how to hook up a kickdown cable assy. I will have ath350 behind it for now with a 200 4r in the near future.
USMC Retired
73 SWB 5.3/4l80e
Build Thread:
Old 03-12-2011, 04:19 AM   #10
ls1nova71
ls1nova71's Avatar
Your intake will most likley have the provisions for the throttle cable bracket, but probably won't have the threaded inserts in them. You can take them out of a junk intake and they just press in. Then you can just get a wiring harness for DBC and a PCM to march and you should be good to go. I would try to find a 411 PCM because they're plentiful and easy to tune. The 2004 may or may not have IAC drivers in it, so it may or may not be able to run a DBC tune.
And try the conversions and hybrids section of ls1 tech.com, you should be able to find out how to hook up your kick down on there as I've seen it done alot, but haven't done it personally. Shouldn't be too hard I wouldn't think.
ls1nova71 is offline   Reply With Quote
