Old 03-11-2011, 10:58 AM   #1
PLANETGETLOW
Fuel Tank - Fuel Lines and Eletrical Help
I know this can't be too hard to figure out but I removed the tank behind the seat and will be going with an under-bed tank.
Does anybody have a drawing or schematic that illustrates where the fuel lines go from the carb, to the tank? Also, how about the wires from the gauge to the sender?
PLANETGETLOW is offline   Reply With Quote
Old 03-11-2011, 11:58 AM   #2
Bruce88
Bruce88's Avatar
Re: Fuel Tank - Fuel Lines and Eletrical Help
I installed a blazer style tank and ran my fuel line down the RH frame and I was also using a vapor/charcoal canister and ran my vent line down the RH frame rail. As for the wire from the sending unit, it was run over to the LH frame and run with the tail light harness to the front going to the fuse block. There are a number of pictures on my build thread that might give you an idea of where you might want to run yours. (See post #301 thru 311) on the build thread http://67-72chevytrucks.com/vboard/s...318544&page=13
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 03-11-2011, 12:12 PM   #3
PLANETGETLOW
wow, your topic is GREAT!!
