Old 03-11-2011, 02:46 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
where to get Ubolts?
Where can i pick up some ubolts for my rear axle when i put my drop springs in?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 03-11-2011, 02:55 PM   #2
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: where to get Ubolts?
If there is a trucking "big rig" shop near you, they should be able to make them to whatever size you want.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-11-2011, 02:56 PM   #3
ldgn63
a spring shop can build them... i bought mine from EARLY CLASSIC (since they come with the super track bar kit)
ldgn63 is offline   Reply With Quote
Old 03-11-2011, 02:56 PM   #4
hotrodhomi
hotrodhomi's Avatar
I got mine from LMC. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=137
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 03-11-2011, 02:56 PM   #5
cdowns
cdowns's Avatar
any autoparts store can get required ubolts
if installing dropped coil springs theres no need for ubolts
Old 03-11-2011, 02:59 PM   #6
leddzepp
Moderator
leddzepp's Avatar
I got a set at oreillys
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-11-2011, 03:00 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Unless the threads get all jacked up when removing 35+ year old nuts off of the bolts. That's what happened to mine when I removed them to lower my truck.
I got mine from a local spring shop. Guy bent and threaded them up in about 15 - 20 minutes.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-11-2011, 03:03 PM   #8
BIGBLU 72
BIGBLU 72's Avatar
aight cool! thanks for the quick responses! my are screwed all to heck and back so i gotta get new ones
Old 03-11-2011, 09:32 PM   #9
GASoline71
GASoline71's Avatar
Eons of crud and rust will do that to them no matter how much liquid wrench you use. Plus the new ones make reassembly so much nicer.
Gary
Old 03-11-2011, 09:48 PM   #10
BOZO
Old School
BOZO's Avatar
I think what cdowns was talking about is, you don't have to remove the axle u-bolts to put in springs. New replacement bolts aren't hard to find through our forum vendors, but extended ones for 2" drop blocks were harder for me (at least) to find. I ended up having a set made at my local machine shop for $30.00.
#1 Project...69 Chevy swb Fleetside (Dad's truck)
#2...1983 El Camino SS (Choo Choo Custom)
#3...1974 Datsun truck (4.3L V6/4L60E)
#4...1951 Cadillac Limo (1975 Caddy running gear)
#5...1938 Dodge M38 3/4 ton Military truck
#6...1968 Sportster XLCH trail bike
5 GMC & Chevy parts trucks 68 to 72
Last but not least;
My 1978 Harley Davidson Electraglide
(trusted & reliable companion for the last 30 years)
BOZO is offline   Reply With Quote
