Old 03-11-2011, 02:52 PM   #1
longhorn70gmc
longhorn70gmc's Avatar
Shift Lever for TILT Steering Column
Hello all,
I purchased a newly refurbished steering column from Brothers last year and finally got it in and I am sadly striking out getting the shift lever or correct one to fit. The lever in the picture is supposed to be the correct one, but it goes in about 1/4 inch and is very tight. I don't want to force it and cause damage to the column, because when I pull it back out there is shavings from the column piece. My question is for those whom have done this; does the lever in the picture look correct and is there any mod I have to do to get it to fit properly? I am debating on grinding a little bit on the sides until it fits. I have verified elsewhere that this is the correct one, but I just want to make sure. As always thanks all.
R/
Billy
1970 GMC Sierra Grande 402/TH400
(Longhorn)14 years and counting rebuild!
1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches
1970 Ford F250 Ranger 390 BB
2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires
Hub Cap Freak!
I need another truck like I need another hole in the head!
I'M IN THE MARKET...AS IT WERE!
longhorn70gmc is offline   Reply With Quote
Old 03-11-2011, 04:24 PM   #2
70shortfleet
70shortfleet's Avatar
Re: Shift Lever for TILT Steering Column
Yes, that is the correct lever for a tilt. It is the paint or powder coat that is making it tight. It wouldn't hurt to grind a little but do not grind past the part that would show!
70shortfleet is offline   Reply With Quote
Old 03-11-2011, 05:45 PM   #3
longhorn70gmc
Thanks Bro for the heads up. The outer shell looks like it is powder coated on the column. On the shift handle I will only grind the side that you don't see and I will keep it inside the best I can on the part that accually goes in. I really appreciate you verifying this for me, because I was scraching my head on this one.
R/
Billy
Billy
Hub Cap Freak!
