#151 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Finally starting the 68swb fleet
subscribed
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#152 |
Master Procrastinator
Look at you guys all jumpin in to the build
![]() Posted via Mobile Device
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#153 | |
![]() Or still having too much fun. Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
#154 |
I am actually replacing some parts on my work truck tomorrow and then I have 2 weeks to get my driveway clear or the city is going to fine me and remove my cabs and parts outta the driveway so should be a rolling chassis to some degree, going to grind and paint my trailing arms tomorrow evening
#155 | |
![]() Looking forward to your updates ![]() Spike ![]()
#156 |
I am way behind you now, but it's motivation and I am able to bug you for info on steps
#157 | |
It's just a matter of enjoying the journey. Spike ![]()
#158 |
For sure racing isn't how I want to do this build. I spent a good hour grinding on the trailing arms and something let loose in my garage lost all power so I'll be back at it tomorrow after my electrician come over, hoping its just a short in my extension cord or something simple, either way I have more outlets than just the garage
#159 |
Hey, if you are looking to change direction a little i got a line on some stuff. I know its a little late because you have done so much **** to your frame but I am throwing this out for you, a swb porterbuilt dropmember frame as a roller, assembled for $4500 and add 12" willwood front and rears for another $1000. That all the bags, crossmembers, rack and pinion, steering components, spindles, all put together and painted. In Calgary. All the stuff is from porterbuilt fabrication, my order was over $6000. Would also save you on grinding rotors possibly.
67' Shortbox build thread:http://67-72chevytrucks.com/vboard/s...=1#post4281123 |
#160 | |
#161 |
nothing major, work has picked up so after the gym it's hard to stay motivated. After a bit of ginding, some preventative rust converter, primer and paint they're ready for installation hopefully tomorrow. Also began the box teardown, only one box side worth saving but that was understood when it was purchased
#162 |
Trailing arms look great!!
![]() Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost Last edited by spike38; 06-09-2011 at 02:19 AM. |
#163 |
Thanks, I put another coat of black on them tonight and started some work space clean up, may coat them in silver to match the steering components though haha, may accent nice with the rest of the silver, hoping for some better updates next week on my days off. Ordering my needed passenger fender and poly body mounts tomorrow.
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project Last edited by tantrumpipeline; 06-10-2011 at 02:21 AM. |
#164 |
Nothing overly major to update, installed the rear suspension as a mock up, not sure if I installed the rear spring retainers correctly? trailing arm and lower retainer bolts are 3/4in too short so tomorrow I'll try and get off work early enough to get to the fastener store, get my rotors machined at the brake shop, and pick up some paint to coat up the remaining steering components. Also installed the cpp transmission mount loose, had to get the box off the floor and outta the way
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project Last edited by tantrumpipeline; 06-15-2011 at 01:27 AM. |
#165 |
pics of the disaster in progress
#166 |
Looking like progress!!!
Spike ![]()
#167 |
Little bit I need to get off early to get the rotors machined and get the fasteners but with any luck today or tomorrow that'll be done
#168 |
rotors are machined, best $40 I've spent in awhile, way nicer look than the grinding I would have pulled off
#169 |
Lookin good,keep it up.
Jay Barrhead,Alberta,Canada 1967 GMC 400sb Porterbuilt stage 2 front and rear suspension ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=419519 |
#170 |
VA72C10
![]() Join Date: Mar 2008
Nice progress!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#171 |
thanks guys, I'll try and get better pics tomorrow in the garage, as it comes together
#172 |
frame looks great!
chevys the way to go. ![]() ![]() |
#173 |
Looks good man!
![]() I love the before and after of each piece. Spike ![]()
#174 |
started in on the steering and front end, CPP shipped the wrong tie rod sleeves and the tire shop the wrong lug nuts, not a major, installed the steering box and started with the rest of the steering, hoping I can find the stock sleeves in my scrap pile tomorrow and should have lug nuts tomorrow, I will post pics of the chassis tomorrow, with any luck the cab will be temporarily on as well
#175 |
Everything's looking really nice. I loved puting my cab back on. Temporary or not, it's a good source of motivation to see it start to look like a truck.
'67 C10 Last edited by David67; 06-20-2011 at 01:38 AM. |
