Old 03-12-2011, 09:41 PM   #1
jessewebb
jessewebb's Avatar
HELP with CPP lowering kit
Got my lowering kit installed. Wasn't to big of a job. Thanks for the help lolife 99
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 03-13-2011, 03:17 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: HELP with CPP lowering kit
If Keith (lolife) helped ya, you got great advice!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-13-2011, 04:05 PM   #3
truckindude
Looks great!
truckindude is offline   Reply With Quote
Old 03-13-2011, 04:07 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Looks good!!!
Old 03-14-2011, 03:39 PM   #5
19seventeeCustom
looking good,
x2 on lolife,, he has already helped me out a ton.
19seventeeCustom is offline   Reply With Quote
Old 03-14-2011, 04:10 PM   #6
leddzepp
Moderator
leddzepp's Avatar
lookin reeeallll good!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-14-2011, 04:10 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
Looks great!
What total drop did you end up with?
You know,... you will just want to keep going lower.
It's an addiction.
Keith
Convert to disc brakes.
Old 03-15-2011, 07:27 AM   #8
jessewebb
jessewebb's Avatar
4" in the back, 3" up front. Glad I did the rear first, it was the hardest. When a bolt has been in the same place for 40+ years it doesn't seem to want to move to easily. Used my grinder quite often. Oddly the front was a breeze. Everything came out rather easy. I got alittle confused with the shocks but after trying to install one I figured out right quick which set went where. I am satisfied with the results. I could really use a garage tho.... Thanks lolife99, Won't be long i'll be buggin you some more, Ordered the park brake cables from inline tube, should be here any day.. Thanks again
Pete
04 325i lady's ride
Old 03-20-2011, 02:54 AM   #9
pawpz
Nice! Were you able to get some step by step pictures? I'm getting ready to tackle the same job...
pawpz is offline   Reply With Quote
Old 03-20-2011, 11:07 AM   #10
jessewebb
jessewebb's Avatar
No, wish I had. Kinda had my hands full. I'll be glad to answer anything I can for ya, when you get started. Best advice I can give you now would be, do the rear first, it was the hardest and took the most time, Only because you have to change the location of the shocks, have to grind or drill the rivets out. I used a grinder. I bought the kit from CPP. It had everything I needed, didn't have to run to the parts store for bolts or this or that. Good luck, I'm sure you'll like the results.
Pete
04 325i lady's ride
Old 03-20-2011, 11:58 AM   #11
pawpz
Did you go with tubular control arms on your set up? Was there any welding involved?
Old 03-20-2011, 07:41 PM   #12
jessewebb
jessewebb's Avatar
no i didnt go with the tube. I just used what was already there, I got the springs and shocks for the front and back, shock relocators for the rear, upper and lower brackets, trac bar, all the bolts were included, and the spring keepers top and bottom for the rear, dropped it 4' in the rear and 3' up front. I'm very satisfied with it.
Pete
04 325i lady's ride
Old 03-20-2011, 08:04 PM   #13
pawpz
Nice job! Thanks for the info...
Old 03-20-2011, 09:32 PM   #14
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
that looks good dude!
springs up front? if so did you have alignment problems?
lowlife is the MAN!
John
1999 Toyota Tacoma 4x4
Old 03-21-2011, 06:36 AM   #15
jessewebb
jessewebb's Avatar
Yes, coils up front and in the back. I haven't had the alignment checked. I haven't really felt much difference in it. But I am planning to change my wheel and tire set-up. I will defiantly have it done then. Thanks
Pete
04 325i lady's ride
Old 03-28-2011, 03:28 PM   #16
jessewebb
jessewebb's Avatar
took my truck to have the alignment checked. Need upper ball joints. Just gonna replace the whole thing, tie rod ends, upper and lower ball joints, sleeves, and the idler. pitman arm looked ok. might just change it to. I've already replaced the upper and lower bearings in the steering column. Hope my steering jack doesn't start leaking...
Pete
04 325i lady's ride
