03-13-2011, 10:54 PM | #1901 |
Re: What did you do to your truck today!
It's been a productive weekend
Installed my new crate motor Dialed in my 700r4 Connected my relocated tailgate handle Plugged holes in firewall Painted the screen on my cowl hood and bolted on the truck Began installing passenger door parts.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
03-13-2011, 10:59 PM | #1902 |
When I was over at Wes's shop www.classicheartbeat.com he had some interesting kick panels that take six inch round speakers I think but may take smaller ones. I haven't got to the install sound part of working on my 71 yet so haven't picked up a set.
03-13-2011, 11:41 PM | #1903 |
I bought some kicks w/ 6 1/2 cut outs for speakers from the truckandcarshop.com. I think they were around 70 bucks. Hopefully they come in next week so I can finish the install next weekend.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
03-14-2011, 02:19 AM | #1904 |
Too many projects
Started it up and let it clear up a bit. Put a 35 back on the front passenger side and organized all my parts that are in the back of it. Oh, and I took about 20 gallons of diesel from it and put it in my dodge engine donor. (out of cash, needed fuel and the burb has a 50 gal in her).
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" Last edited by lowrollin70gmc; 03-14-2011 at 02:19 AM. |
03-14-2011, 11:15 PM | #1905 |
RAT1968 '68 Cab/'71 Parts
Gutted it up and went to the shop to finish the rear brake shoe replacement on the passenger side. Nasty job. I gotta go with rear disks some day.
Put caps on the rear Boss 338 20's using some black silicone on the "o" rings; Torqued down the 1" spacers to 95 lbs.; Painted the inner rear fender wells with gloss black to go with the flat black rat-exterior. Painted the drums gloss black, too. Put the wheels on the back for now... just to get them out of the way. Okay, okay. I wanted to see them on the truck again. Another mock-up on the dash with the new tilt installed. Put a lazer-sight on my .380... Oops! That's another Forum....
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 03-14-2011 at 11:20 PM. |
03-15-2011, 09:24 PM | #1906 |
My daughter took me and the truck to get some limestone block so she could redo the planters out in front of house.
Of coarse she sat in the truck eating candy, while dad loaded the 436 lbs of block... smart kid! Last edited by AustinScott; 03-15-2011 at 09:28 PM. |
03-15-2011, 10:55 PM | #1907 |
Worked on my speedo gear today. Used one of the FAQ's on the site to determine the right drive gear and driven gear and then ordered the parts. Pulled the drive line and tranny tail shaft housing to get to the gears. Pretty straightforward and easy to do with some help from the board. Figured out I got 3.73 rearend. Also figured out I have a leaky pinion seal. I think I will fix that tomorrow since I've got the drive shaft out.
03-16-2011, 01:01 AM | #1908 |
Well I'm having my Interior completly re-done,
so I bought a "Billet Steering Column Dress-up Kit". Turns out that my 4 way Flasher button (Red one on mt Column), is part of the switch, so my "Billet 4 Way Flasher Knob" wont work. .......That is until TODAY, when I found out the Signal Cam & Switch were Broken/Cracked. The replacment switch has provisions to use the "screw in Billet knob".
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
03-16-2011, 01:20 AM | #1909 |
Sofa King Crazy!!
^Nice!
I started tearing my motor down because I was given a cracked block by the engine builder. He's gonna get another block and make it good.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-16-2011, 01:35 AM | #1910 |
yes, i do
well at least he's doin right by you and replacing the block slick. that's someone that i would recommend in the future. it sucks but at least he's correcting his mistake/oversight
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
03-16-2011, 01:46 AM | #1911 |
Sofa King Crazy!!
I hope. He took one week short of a year to get my engine done the first time then this comes up. I am still pissed, but at least he "says" he is gonna make it right. Hope it isn't another year.
03-16-2011, 08:51 PM | #1912 |
got my cab all stripped down..now i need to get it soda blasted ..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
03-18-2011, 08:51 AM | #1913 |
Recieved my new dash bezel and kick panels from truckandcarshop.com. They look pretty good. Dry fit the kick panels, trimmed one a bit and shot a coat of paint on them. Pounded out the pinion seal off my tail cap housing and rear diff. Those babies were on there!
03-18-2011, 09:49 AM | #1914 |
Went to the powder coating shop and picked up my core support ,inner fenders ,battery tray and a few other parts.I then went to the shop doing my truck and helped weld up some holes in the bed.Clamped the hidden hitch in place to mark the holes to be drilled and then left her again.
03-18-2011, 10:47 AM | #1915 |
I made a ''Crafty'' brace for my alternator bracket
Did it a few days ago, but thought it may be worth putting up here |
03-18-2011, 11:56 AM | #1916 |
Member
Finished the air ride.. Bring on spring!
69 C10 SWB 406 SBC 08 Silverado HD 2500 LWB Crew Cab Diesel. 06 Trail Blazer SS (Wife's Daily Driver) 67 RS/SS G-Machine http://www.hubgarage.com/mygarage/RBC67 |
03-18-2011, 12:02 PM | #1917 |
Registered 1971 K5
03-18-2011, 01:14 PM | #1918 |
yes, i do
At least it will have a lifetime warranty on it right?
03-18-2011, 04:42 PM | #1919 |
Florida Edition
Pulled the entire rear out from under my longbed frame by myself with the help of these dollys I bought from Summit..money well spent!
Note the baby carriage tool cart..rolls free and holds lots of stuff.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
03-18-2011, 06:16 PM | #1920 |
Old Skool Club
I see you have the same kind of inverted rear end that I had..... It's a lot easier to take the trailing arms loose, fo sho. Now that my rear end is free of all its' encumbrances...my son want us to pull the third member/axles and backing plates and sand blast the housing (outside). I'm not in favor. I don't want any sand inside the housing or axle tubes...and I'm not convinced that it can be done without that happening.
As for what I got done.....got my newly acquired and painted Wheel Vintiques 16x7's mounted on my '96 GMC. I lost the rake that it had, but I can rotate tires and get some better mileage out of these.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
03-18-2011, 07:22 PM | #1921 |
Redefining LowBudget
Booterd the caddy hard tillthe tires stuck now I have the DS in a vise and I'll pick up the new carrier bearing in the morning
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
03-18-2011, 08:01 PM | #1922 |
Finished installing the kick panels w/ speaker cutouts. Pass side needed a little trimming but the D/S went in fine. Not bad for 70 bucks.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
03-18-2011, 08:19 PM | #1923 |
Washed it, waxed it, took pictures of it (see my thread), and drove-drove-drove. Oh, and had a quote on some wheels and shoes!!! Found out I have to wait on those...$$$$
03-18-2011, 10:24 PM | #1924 |
Not much... just started 'er up and idled 'er for a while. I had to drop the insurance after I stopped working because of medical issues.I also need to do a bunch of work on it, and I'm not too keen on turning wrenches out in the driveway when there's a foot+ of snow around.
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
03-19-2011, 12:58 AM | #1925 |
Got permission from the Wife, to get my Exhaust re-routed up into the Frame, re-Coat everything and install Electric Cut-Outs!
