Old 03-14-2011, 06:03 PM   #1
byates2
byates2's Avatar
New Muscle for a 67 chevy
So im restoring my chevy pickup, its a c-10 1967 and the original motor in it was a 283 with a 2 speed powerglide. I want to put a 383 stroker motor in it with a 4l60e tranny. How hard would this be to do.
And im trying to decide on a fuel pump. Im thinking of going with the standard 1721 110 gph 6 psi or the victor series 1711 that is 130 gph 13 psi but requires a regulator. Would it be worth it to upgrade to the victor series and get a racing pump???
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 03-14-2011, 08:48 PM   #2
mrein3
mrein3's Avatar
Re: New Muscle for a 67 chevy
I swaped in a fresh 383 I built old-school like with a 350 block and 400 crank shaft. It was a direct bolt in just like it would be on your 283 truck. The 4l60e will take some work. I've never done that mod so I can't speak to that. It will bolt to your 283 or 383 but the "e" in 4l60e means electronic. To make that swap easier I'd find a 700r4 and use it. Same tranny, you don't need a computer to run it.
But as far as engines go, a small block is a small block. Anything from a 283 up to a 400 will swap in no problem.
I used the stock fuel pump. Why change from it unless you are going to some kind of fuel injection setup.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 03-14-2011, 08:57 PM   #3
tremman78
tremman78's Avatar
Build up that 283, lots of fun playing in the higher rpm's
tremman78 is offline   Reply With Quote
