03-14-2011, 11:43 PM | #1 |
rear brake ??s
Re: Rear Brake Drum Questions
i would like to thank you both i am going to pull the backs off my 67 3/4 in a couple of days and this will help a whole lot .. had big trucks , years ago almost the same... i have a question i replaced the master and bled all 4 bleeders pedal is up and hard but brakes are still spunge at best ....after driving a while push down goes half way down and pedal pushes/ bumps like a skip back at my foot spungy need to mash on her to get one wheel to lock dont know which one locked believe it was rear couldnt see the tire mark any ideas __________________ 36 1/2 Ton 67 small window Custom Camper 3/4 73 Custom 20
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-16-2011, 04:43 PM | #2 |
Restoration Virgin!
Re: rear brake ??s
ttt
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
03-16-2011, 05:47 PM | #3 |
Re: rear brake ??s
I'd do the wheel cylinders, I'm doin ALL of my brakes and bearings right now, most of the wheel cylinders had a small leak...
03-16-2011, 08:41 PM | #4 |
Re: rear brake ??s
Have you already replaced the shoes/had it apart? Because it is such a pain to disassemble, many people never do the rear brakes on these trucks (mine appeared to be one). Metal to metal doesn't give much friction.
The best mod I did to mine after rebuilding the brakes was to install a used power booster (manual before). Stops great now.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
03-17-2011, 11:19 PM | #5 |
Re: rear brake ??s
i replaced everything wheel cylinders and all... you are right looks like they didn't want to touch the rears the parking brake lever was also hangin all good now
03-18-2011, 12:55 AM | #6 |
Re: rear brake ??s
I'm gettin ready to re assemble everything right now.
I'm surprised how little fluid was left in the lines O: I think the ol truck will stop pretty good, There's quite a bit of surface area for these drums to start slowin the roll. |
