Old 03-15-2011, 08:20 PM   #1
steppside69
steppside69's Avatar
Rear axle bearings
I have a question about the rear axle bearing, I was changing the rear brakes on my truck and noticed what appears to me to be ALOT of play both thrust (About 1/4-3/8") And up and down (About 1/16 + or -") I dont know if that is acceptable or I have a problem?
The truck is a 2006 silverado z71 ext. cab 5.3l
It has 80k miles and has a intermediate noise from 1st to 2nd. Sometimes it will make a clunking sound but will not do it all the time. I also noticed a slight vibration when coasting to a stop light. Thought that it maybe in the tranny so I put the truck in neutral while coasting and the vibration was still there. I hope that there is nothing wrong but my gut is saying something else, Thanks for the info/guidence
Eric
69 chevy stepside (project)
2006 Silverado Z71 Ext. cab
2005 Saturn VUE (wifes dd)
steppside69 is offline   Reply With Quote
Old 03-15-2011, 09:52 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Rear axle bearings
The thrust doesn't sound too far off of normal (c clip type rear) and usually the seal will start leaking pretty quick if the outer bearing is allowing too much up/ down movement.
Vibration I would disconnect the drive shaft and spin the rear by hand and check the u joints.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 03-16-2011, 07:02 PM   #3
steppside69
I checked to u-joints and had to hold the drive shaft while a friend turned the tire. There is some play so i will change the u-joints this weekend.
Will keep you guys informed of the progress,
Thanks again for the info, Eric
