Old 03-15-2011, 08:40 PM   #1
funkytechmonkey
funkytechmonkey's Avatar
What are my axel options?
Here is my delima... I am converting from leaf to trailing arm. I have the rear end that came with the truck. It is a 5 lug from a 71 GMC and have no idea that gears but I know its not a posi. Since I am doing the leaf to T/A conversion I picked up a rear end, just for markup, from a 67 that is a 6 lug with 373 gears. I want to stay with the 5 lug but I'd love to keep the 67 rearend because of the gears and the mounts for the T/A. The only reason Id like to keep the 71 is for the 5 lug.
The 5 lug axels wont work in the 67 because of length...right? So what are my options? Should I just have the 6 lug redrilled for $150 or should I buy the new 5 lug axels for $250?
**ADDED
My benfit of keeping the 67 is shorter axel... I can run wider rear wheels...T/A perch is already there.
The only benefit of the 71 is the 5 lug. I still have to figure out how to mount the T/A perches.
I want to do things right the first time. I am doing a frame off and trying to make sure I build a great truck.
Never wrenched a day in my life and now...
Im doing a frame off restoration on a 1968 C10
with a Porterbuilt Dropmember, Acuair E-Level kit,
Boyd Welds Gas tank and mild c-notch.
Click here to view my build
funkytechmonkey is offline   Reply With Quote
Old 03-15-2011, 08:45 PM   #2
Shane
Shane's Avatar
Re: What are my axel options?
Personally, I would spring for the extra $100 and get the new axles versus drilling 40+ year old axles.
Shane is offline   Reply With Quote
Old 03-15-2011, 09:04 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
x2
Keith
Convert to disc brakes.
Old 03-16-2011, 12:52 AM   #4
SCOTI
SCOTI's Avatar
New conversion axles are a direct swap, have zero bearing wear, & are stronger than OE axles.... what is it you need to think about?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-16-2011, 01:35 AM   #5
funkytechmonkey
Is this ok?
http://www.summitracing.com/parts/SAG-PA5855/
Where else is a good place to get some axels??
Old 03-16-2011, 01:54 AM   #6
stich626
moser
stich626 is offline   Reply With Quote
Old 03-16-2011, 02:42 AM   #7
crazy longhorn
Fabricate till you "puke"
X3.... crazyl
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-16-2011, 10:37 AM   #8
SCOTI
SCOTI's Avatar
Originally Posted by funkytechmonkey View Post
Is this ok?
CPP (board supporting vendor, Jeff is a member here & our 'contact guy')
ECE
Moser
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-16-2011, 11:11 AM   #9
funkytechmonkey
I called moser this morning and they gave me a price for the 5 lug axels with the studs mounted and shipped for around $280. So I purchased them!!
Thanks stich!!
