Old 03-16-2011, 08:59 PM   #51
maynardtruckin
maynardtruckin's Avatar
Re: flat top pistons
I have had several still have a 4 bolt main builder and a 2 bolt main runner. I have plans for the builder not sure what I will do with the runner its a mildly built 400. has a rv cam Edelbrock intake down side is the cheep chrome tins but it runs like a dream.
Chris
67 c10 swb build in progress
70 c10 lwb driver pending parts for drastic overhaul
70 c20 lwb parts truck for above mentioned drastic overhaul
71 k20 lwb building for off road use and towing
maynardtruckin is offline   Reply With Quote
Old 03-16-2011, 09:14 PM   #52
justinburnett
justinburnett's Avatar
Torque is what I'm after more than anything, and seems like they have plenty when they're running right. I think I'm going to be happy with it.
justinburnett is offline   Reply With Quote
Old 03-16-2011, 10:29 PM   #53
85Bowtie
85Bowtie's Avatar
I didn't bother to read through 3 pages of comments, but I'll give you my 2 cents....
If you go with a flat top, you will want to use a closed chamber head along with a piston that gets you at "zero deck".
The reason being is you want quench. Basically, this is the "squeeze" inside the chamber. It has nothing to do with CR, although in many instances it will raise your CR. What quench will do is give you a "complete mixture" inside your combustion chamber. It works by squeezing the mixture out from the "closed chamber area" and creates a swirling effect. This will give you a complete AND efficient burn. In return, it will also help evenly cool the top of the piston and the chamber. What does this mean for you? Lower risk of detonation because of the "cooling" effect achieved from the proper quench.
Also, if you go with aluminum heads you can run about a point higher on CR with pump gas. So a 10.5:1 engine will run on the same grade fuel as a 9.5:1 steel headed engine because of the better heat transfer.
Once you have decent CR and quench, you can pretty much pick and choose a wide range of cams.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 03-16-2011, 10:41 PM   #54
justinburnett
I won't be able to do it right now because of all the money I've spent already but I'll look up closed chamber heads to see what they are for the next time through. Thank you.
