Old 03-17-2011, 12:04 AM   #1
Slow Build
Slow Build's Avatar
Factory A/C
I'm getting this factory (I believe) A/C set-up tomorrow. I'm guessing I should grab every single thing I can from the system. I don't really know much about A/C. I have a few questions:
Any advice or cautions on the removal?
Are there parts available to fix these units when it doesn't work?
Are the heaters any different with the A/C or should I get it too?
Any advice would be appreciated.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-17-2011, 12:33 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Factory A/C
Good score, the heaters are the same but you will have your work cut out for you.You really need to grab the dashboard and every part associated with it. You might want to even consider taking the firewall from the tunnel to the inner fender as there is a cutout for the evap.I don't know if this is the same as non ac trucks. Parts are not available other than the compressor but anything can be fixed,
LT1 Burb is offline   Reply With Quote
Old 03-17-2011, 12:48 AM   #3
Slow Build
Slow Build's Avatar
Re: Factory A/C
I was thinking about getting the dash. The windshield is already out. I wonder how much it would take to remove it. As for the firewall I was going to take detailed pictures of the holes and hope for the best.
Past GM Trucks:
Old 03-17-2011, 01:07 AM   #4
TopFuel1966
TopFuel1966's Avatar
Re: Factory A/C
Arm yourself with a spotweld cutter and several spare blades, a big lunch and a couple of sixpacks.
TopFuel1966 is offline   Reply With Quote
Old 03-17-2011, 01:09 AM   #5
LT1 Burb
LT1 Burb's Avatar
Re: Factory A/C
PM sent
Old 03-17-2011, 01:34 AM   #6
Captainfab
60-66 Nut
Re: Factory A/C
I don't know if they still do, but LMC used to sell some of the replacement parts for the factory A/C.
Old 03-17-2011, 08:19 AM   #7
chevyrestoguy
chevyrestoguy's Avatar
Re: Factory A/C
Take every bolt, screw, bracket, gasket that connects in any way to the A/C system. That stuff is all unique and you'll need it if you want your system to look factory.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-17-2011, 09:29 AM   #8
jocko
jocko's Avatar
Re: Factory A/C
not A/C-related, but I would absolutely make sure you get that original radio in the deal. Might recoup all your expenses with a simply ebay run if you don't want it.
Old 03-17-2011, 08:51 PM   #9
Slow Build
Slow Build's Avatar
Re: Factory A/C
That's what I did. I got everything, even the pulleys and belt. I had to slice the lines to get them off without damaging the hard lines. It was actually still holding a slight charge. If I want to put it in my truck it will take a fair amount of cutting in the dash and firewall. Taking the dash out sounds like alot of work. I'll be going back tommorrow to make some templets for the holes just in case.
Past GM Trucks:
Old 03-17-2011, 10:13 PM   #10
Slow Build
Slow Build's Avatar
Re: Factory A/C
Just in case someone is interested. This is what the firewall looks like on an A/C cab.
Past GM Trucks:
Old 03-17-2011, 10:35 PM   #11
Slow Build
Slow Build's Avatar
Re: Factory A/C
chevyrestoguy PMed me to be on the lookout for other interesting parts on an A/C cab truck. I found a few. The first 4 pictures are of a different type of power steering. The last picture is of an angled power brake booster bracket. Anybody have any ideas of why that would be needed?
Past GM Trucks:
Old 03-18-2011, 12:11 AM   #12
LT1 Burb
LT1 Burb's Avatar
Re: Factory A/C
What does the rest of that truck look like, man a full loader. Make sure you get the pulley from the crank for the AC, also if the PB setup is for sale let me know how much. That PS setup is the stock one.I want to see the pic of the rest of it.
Old 03-18-2011, 12:38 AM   #13
rbar
rbar's Avatar
Re: Factory A/C
As far as the dash fitting the vent work (difuser I think), I got a cad drawing from another member that I am sure is still posted on here somewhere. Alot easier than trying to change dashes. Also, I had the plastic vent balls rechromed and used Plastex to fix the broken corners on the dash vent, which worked awesome.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 03-18-2011, 11:54 AM   #14
chevyrestoguy
Re: Factory A/C
Rich-
You scored BIG time! You got some great pieces that are VERY hard to find, especially if you're looking for them. As far the the angled booster bracket, I've seen them before, but I don't have a clue why they are shaped that way. Maybe one of the gurus on the site can answer that question.
rbar-
Your center dash bezel turned out beautiful. Every time you post up a picture, my jaw drops at how nice your stuff is.
My build threads:
Old 03-18-2011, 12:01 PM   #15
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Factory A/C
You might want to buy a Custom Accessories Installation Manual. They'll have details and measurements for the installation into your truck. Saw a Compressor bracket for the 64-66 go for over $400.00 on Ebay.
If you get the radio don't forget the speaker. If you turn on the radio without a speaker hooked up you'll blow the capacitor.
Check the glove box for the optional light.
Man I wish I was there to scour that truck!
Positraction Differential?
Reverse switch on the 4 speed?
Just take the whole truck!
Old 03-18-2011, 02:16 PM   #16
rbar
rbar's Avatar
Re: Factory A/C
Thanks restoguy, it still needs painted, but I was happy with the repairs.
1965 Chevy swb 383
Old 03-19-2011, 12:52 AM   #17
Captainfab
60-66 Nut
Re: Factory A/C
I think the angled brake booster/master may have been for clearance for the I6 air cleaner.
Old 03-21-2011, 06:02 PM   #18
Slow Build
Slow Build's Avatar
Re: Factory A/C
Here are some pics.
Past GM Trucks:
Old 03-21-2011, 06:49 PM   #19
jocko
jocko's Avatar
Re: Factory A/C
that's too cool! What a loaded truck, hard to imagine. Sure makes one-stop shopping nice though. Maybe that angled brake booster could be used to clear some absolutely massive headers!!!! (just kidding) - I like Captain's guess and I think I've heard that before somewhere (i.e. I6 air cleaner clearance) - that makes sense to me. But it looks like the truck came with a V8??? The plot thickens....
Old 03-21-2011, 10:09 PM   #20
yelmer
Re: Factory A/C
hello get the heater box they are different for ac trucks also get the fan with it if it the original fan, it is bigger mike
yelmer is offline   Reply With Quote
Old 03-21-2011, 10:26 PM   #21
yelmer
Re: Factory A/C
also get the radiator 4 core was standard for ac trucks tank measures 3-1/2" and brackets on top and bottom with cushions nice pickup on the ac stuff. mike
Old 03-21-2011, 10:30 PM   #22
stage1455
Re: Factory A/C
I'm still looking for one...
Thanks,
Meridian, ID
stage1455 is offline   Reply With Quote
Old 03-21-2011, 10:54 PM   #23
LILJP's66
Re: Factory A/C
Hey slowbuild is this truck at the pick in pull across from hurtado's in brentwood?
LILJP's66 is offline   Reply With Quote
