Old 03-15-2011, 08:29 PM   #1
oldwagon
oldwagon's Avatar
Window Vents
Since I am replacing the doors on my '83 and I really need to replace the vents, does any one know if '73 to '87 vents will fit or will I need to narrow it down more? The doors are off of an '83 Sierra.
oldwagon is offline   Reply With Quote
Old 03-15-2011, 09:15 PM   #2
grim626
grim626's Avatar
Re: Window Vents
you gonna want to narrow it down to 81-87
1984 chevy LWB 4wd
4" lift w/33's
grim626 is offline   Reply With Quote
Old 03-15-2011, 11:30 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Window Vents
i put 89 suburban vents with a locks, in the 78 jimmy didn't have no probs
glass is thinner,couple of bolts diff but no biggie
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-16-2011, 10:50 AM   #4
BigRed76
BigRed76's Avatar
Re: Window Vents
all 73-87 vent windows are the same, the only small difference is that some of the 80's vents windows dont have the middle screw on the top of the door, but you can easily drill the hole a put one there if you need it.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 03-16-2011, 04:04 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Window Vents
That was my experience, kind of. I put a window from a 70s truck in my '86. There just wasn't a place to put the middle screw, so I left it out.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-16-2011, 07:59 PM   #6
grim626
grim626's Avatar
Re: Window Vents
yeah i was going off catalog info
1984 chevy LWB 4wd
4" lift w/33's
Old 03-16-2011, 08:04 PM   #7
87 chevy silverado
Re: Window Vents
and the locks are diffrent
87 chevy silverado is offline   Reply With Quote
Old 03-16-2011, 08:33 PM   #8
BigRed76
BigRed76's Avatar
Re: Window Vents
That is true, but as far as i know they can all be switched out for the other style.
Zach
Old 03-16-2011, 08:42 PM   #9
87 chevy silverado
Re: Window Vents
very true
Old 03-17-2011, 07:51 AM   #10
SeanPaintsFlames
SeanPaintsFlames's Avatar
Re: Window Vents
If you're switching the whole assembly, then yes, you can put an older vent window in a newer door. There are some differences in where it pivots, how wide the run channel is, and the latch. You can't switch components between the styles.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-17-2011, 11:02 AM   #11
oldwagon
oldwagon's Avatar
Re: Window Vents
Thanks for the input, guys. I appreciate it. I was going to go ahead and have the doors installed on the truck, but my BIL more or less convinced me to go ahead and get the doors rebuilt and then put them on the truck.
Old 03-17-2011, 11:43 AM   #12
joe231
joe231's Avatar
Re: Window Vents
I was under the impression that the 73-76's are different...
I don't remember for sure though. I know the 77-91's will swap though...
If you can find used from a 89-91 Burb, blazer, or crew they seem to be in pretty decent shape from my experience anyway....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 03-19-2011, 03:41 PM   #13
73gmc454
73gmc454's Avatar
Re: Window Vents
I put newer vents in my older doors and there was a gap in the seal where the middle screw would be in the left side , so I just cut the top of the off of the old middle mount and welded it carefully to the nos vent ! it pulled the seal right in ,
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
