Old 03-17-2011, 08:42 PM   #1
kfreeman1966
Brake System Troubles
Ok here goes- I have a 66 with a 350 engine. I have been completely redoing the truck from frame off...... I have new brake lines from front to rear.... Disc on the Front... Drum on the back... a new master/booster combo from Tuff- stuff.... I have completely redone the rear drums all new stuff... as well as the fronts... I used the old calipers though because they are in really great condition. Here is the problem... after completely bleeding the system, I have a great hard brake pedal until I crank the engine, then the pedal goes right to the floor........ I have re-blead the system and checked all the line connections...
???? anyone have any answers as to how to fix this ????
Thanks, Keith
kfreeman1966 is offline   Reply With Quote
Old 03-17-2011, 09:06 PM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Brake System Troubles
Are you getting a good straight stream out of each bleed valve? Did you top off the reservoir?
Old 03-17-2011, 09:29 PM   #3
kfreeman1966
Yes, I'm getting a pretty good stream out of each bleeder valve. and I did make sure and top off the reservoir.
Old 03-17-2011, 11:48 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Are the rear drum shoes adjusted out for a friction fit when installing the drum??
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-18-2011, 05:29 PM   #5
kfreeman1966
I checked them and the are rubbing the pads when I turn them. I have also spoken with another guy, and he said to check the vacuum when the motor is at 2500 RPM. I did and still no luck. .... I bleed the line into a bottle of fluid bubbles come out I shut it down when the bubbles disappear. I do this on all 4 wheels. I have a really hard pedal, I start it up and the pedal goes right to the floor. I start over bleeding and bubbles come out.....I've done this process about 6-8 times.... UUUGGGGHHHH!!!!!!!
Can you say frustration!!!
Keith
Old 03-18-2011, 07:06 PM   #6
Clyde65
Clyde65's Avatar
bad booster?
Do you have good vacumn on your hose to the booster?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
