Old 03-18-2011, 07:52 AM   #1
no moa
no moa's Avatar
WTB 69 1 ton rear spring perches
I was using the wrecker this morning, and i climbed under it and noticed the rear spring perches have rust holes in them, so i need to replace them.
Also found a crossmember thats bad, but thats another day.
Cheap would be great, free would be better. lol. I'd like the non swiss cheese versions also.
Glen
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 03-18-2011, 02:33 PM   #2
StingRay
StingRay's Avatar
Re: WTB 69 1 ton rear spring perches
You can make spring perches easy enough. Hole saw a half moon through a piece of rectangular tubing or some channel. I'm keeping the set that's on the HO72 out back. I will be scrapping the frame though. Some of it's rusty some of it not so bad. Which cross member do you need. If I have a good one I'd save it for ya. Shipping would be the killer but I don't need anything for it either.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 03-21-2011, 08:57 AM   #3
no moa
no moa's Avatar
Thanks stingray, i was some factory perches,
I'm not sure which crossmember it is yet, I'll get pics of it, I can just see the holes through the body. But haven't layed in the mud yet. I'll let you know.
Glen
TTT for anyone with stock rear frame perches.
Old 03-21-2011, 09:46 AM   #4
StingRay
StingRay's Avatar
My one ton only has about 60K original and the factory spring perches were not all that hot. Not rotten through by any means but the mating surfaces were pretty eroded. If you do find some see if they can sacrifice the housing and leave you a good amount of material to work with. I'd consider having them milled at the mating surface too to so that everything sits nice and true. If I had to replace mine I'd just build my own. Does yours have the spacers between the housing and the sping? Factory spacers have a bit of wedge built into them for pinion angle and can be prone to cracking. If you have these take them and sand blast them good. I welded mine up to repair them. I also spent a pile of time with a file and grinder truing the perches and spacers to eachother because of corrosion.
Canada
Old 03-21-2011, 09:55 AM   #5
no moa
no moa's Avatar
I didn't look that close, i just saw the holes in them. I'm going to try to get some pics later. And i'll check for the spacers.
Old 03-21-2011, 09:58 AM   #6
67cheby
67cheby
67cheby's Avatar
i just posted a set in the for sale section
67cheby is offline   Reply With Quote
Old 03-21-2011, 10:16 AM   #7
no moa
no moa's Avatar
Leaf spring perches?
Old 03-21-2011, 10:19 AM   #8
67cheby
67cheby
67cheby's Avatar
no sorry they were coil spring , my bad
Old 03-21-2011, 10:46 AM   #9
no moa
no moa's Avatar
Ok, thanks for the heads up though.
Old 03-22-2011, 01:12 PM   #10
OldCreek
OldCreek's Avatar
I might have a pair. Do these push the spring mounting width outward? I think what I have is 73+ and probably 3/4ton. Got a picture? I've gotta go to the barn to find them...may take a while.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-22-2011, 01:44 PM   #11
no moa
no moa's Avatar
No pictures yet, it snowed like crazy here so I can't get to them. I'll post them up when I do.
Old 03-25-2011, 08:31 AM   #12
no moa
no moa's Avatar
Here are some pics, they are pretty bad now that i cleaned them out of crap.
THe last 2 are the rusted out crossmember.
Old 05-23-2011, 08:01 AM   #13
no moa
no moa's Avatar
Ttt
Old 06-08-2011, 10:39 AM   #14
no moa
no moa's Avatar
TTT again.
Old 06-08-2011, 12:31 PM   #15
CUSTOM/10
CUSTOM/10's Avatar
I may have a set off a 72 Blazer if there the same. Blazer came from Ca. so I believe there in nice shape. Were abouts in Maine are you ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 06-08-2011, 01:04 PM   #16
no moa
no moa's Avatar
Gary
I'm in Bath.
I don't know if they are the same or not. I think the 1 tons are more heavy duty. I'll take some measurements when i can.
Thanks Gary,
Glen
Old 09-14-2011, 06:51 AM   #17
no moa
no moa's Avatar
TTT still need a set.
Old 09-21-2011, 03:00 PM   #18
no moa
no moa's Avatar
TTT
Old 10-20-2011, 12:41 PM   #19
no moa
no moa's Avatar
ttt
Old 10-20-2011, 02:14 PM   #20
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I have a new set of spring perches for a Dana 60 that I do not need as I'm sticking with my Eaton. Do you need Eaton or Dana perches?
Old 10-20-2011, 03:53 PM   #21
no moa
no moa's Avatar
I have no idea what is in the truck. I'll do some checking but I believe it to be factory.
