1969 Custom 30 wrecker
Did trucks that came with the rubber floor mat also have a heavy tar like sheet material under that and a white foam pad under that? Not sure if the foam is original. ??
Here's a pic showing the foam, I had already pulled up the tar sheet material which sat on top of it. Thanks, Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
its all about the +6 inches
Re: Floor mat & underlayment
yep. its under the longhorn's mat
68 C20 had the tar mat on the metal floor, white foam on top of that, then rubber mat. looks to be the same foam as mine.
I think that would make more sense. Maybe someone had mine out and put back in wrong?
Anyone else?
My suburban came that way too rubber, foam, and tar on the metal
1953 Chevy 6400 Truck - 2 Ton Pickup Project - 5.9 CTD, 6 Sp Allison, Air Ride, 22.5 Wheels 1952 Chevy 6400 Truck - Looking for a direction in life |
Thanks, that's the way it's going back together then. I haven't found the foam yet but the other items are available.
#7 | |
Florida Edition
![]() ![]() Join Date: Oct 2010
Your wrecker is brutally cool.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
For some reason that foam reminds me a lot of the underlayment that is used for laminated wood flooring, i'm not too sure if it's exactly the same but it looks awfully similar.
From what I can tell the older trucks like the 67's had the tar right on the metal floor. That is why you nearly have to use a chizel to remove it sometimes. On all the 72"s i have seen the foam is under the tar which is good because you can lift up the foam and remove it in tact and reuse it if possible.
72 Cheyenne Super 80 Silverado Blazer 2wd |
Original 72 w/tar on top of foam.
Hand Crafted C-10
![]() Join Date: Aug 2006
Dang you guys made me go out in the dark but...walla!
![]() Floor, stock sound deadener (tar-mat), foam and rubber mat on top. Stock 1968 C-10 The mat is not glued to the floor but seems to have an oil-impregnated paper coating on both sides; not sticky at all. Almost resembles an expansion joint used in concrete work, but thin. Last edited by ETsC10; 03-22-2011 at 01:43 AM. Reason: added info |
My 68 was the same as ETsC10 and if you find a foam or insulator let me know I'm lookin for a replacement at the moment too. Best for the money I can find is : https://www.shopatron.com/products/p...er=14720/681.0
or https://www.shopatron.com/products/p...er=14620/681.0 |
My 71 had the mat, tar, then the white foam on the metal. My dad bought the truck in 1972 and the mat had not been pulled out before I took it out. As evidence of this, under the foam I found a brand new plastic indicator plate for the key switch that the guy at the factory must have dropped. It was very neatly imbedded in the white foam next to the tranny hump.
Wow, now we have it both ways.
Guess I'll take my pick as to how I want to put it back. ![]()
