Closed Thread
Old 03-21-2011, 07:39 AM   #2726
jbgroby
jbgroby's Avatar
Re: What did you do to your truck today?
NETO,
Is the fire wall color called "Mesa Tan" is that the color, you don't see it often anymore.
jbgroby is offline
Old 03-21-2011, 11:26 AM   #2727
neto
neto's Avatar
I really don't know. I just got it a week ago. The outside is the same but it was painted once from what I can see. The grill had some paint on it. All the areas that are usually not painted are the same color, so I think it's original. Some one with more knowledge might know.
neto is offline
Old 03-21-2011, 08:15 PM   #2728
mudderphil
started getting the engine ready to come out only so much i can do on a hour long lunch time as im doing most the work at work in the shop when its not full of other cars.
mudderphil is offline
Old 03-21-2011, 08:33 PM   #2729
awbrown
Took the heater apart and found out why it didnt blow any air.. it had a mice condo in it.. blasted the housing with black beauty to get rid of the smell...Also put in a new set of plugs .. I think the way it is running on part throttle tells me it needs a power valve on the primary side , I will save that for next week when it is back in thje 50's again....
awbrown is offline
Old 03-21-2011, 11:02 PM   #2730
jbgroby
jbgroby's Avatar
With the help of a friend "Tom" in Coastal Cruisers, I was able to remove the funky steering wheel. I still need to pick up 2 7/16" x4" long bolts because of the small bolts for the old wheel. Was too late to run the 10 miles to the Home Depot tonight.
jbgroby is offline
Old 03-22-2011, 12:16 AM   #2731
nachodog2
Hell yeah!!!
nachodog2's Avatar
Originally Posted by LILJP's66 View Post
how did you buld this homemade tonneau cover?
I'll post pics by wednesday, it's super easy and so far less than $90. Still gotta get hinges and the marine pleated vinyl though. I'm looking at less than $200 total.
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 03-22-2011, 12:19 AM   #2732
LILJP's66
are you bagged or just lowered? and what city are you
LILJP's66 is offline
Old 03-22-2011, 12:23 AM   #2733
nachodog2
Hell yeah!!!
nachodog2's Avatar
Just lowered, though I run airshocks to give a little lift, maybe three inches or so. The picture shows it aired up. I live near Six Flags Magic Mountain.
Old 03-22-2011, 12:26 AM   #2734
LILJP's66
what size shocks? i've been debating lately bags or shocks.
what about the front?
Old 03-22-2011, 12:30 AM   #2735
nachodog2
Hell yeah!!!
nachodog2's Avatar
Have no clue on the shocks, my brother had them for his car, did not fit I came up on them, check my build thread, it has pictures of the shocks. You may be able to tell what they are. The front just has two rings cut out and bump stops removed on '73 control arms.
Old 03-22-2011, 12:33 AM   #2736
LILJP's66
cool man thanks. I have a set off a 67 mustang guess i'll try them
Old 03-22-2011, 12:54 PM   #2737
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Yesterday I went by the DMV and got the registration all finished up, so now she is all tagged and plated. And of course, 100% mine! I think today we're just going to be hauling a load to the recyclers. But that depends on what the weather does, it's trying to start snowing again.
fryer1979 is offline
Old 03-22-2011, 06:47 PM   #2738
Real_McCoy
Real_McCoy's Avatar
Congrats!!! I need to get my white 66 registered before I go too far with its build. I am ready to tear it apart, but need it running to get the registration done. ARGGGHHH!
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline
Old 03-22-2011, 07:48 PM   #2739
1966Stepside
1966Stepside's Avatar
Brought it home from the body shop. time to make it handle, stop, and run better with an '82 front end and a 4.8/4l60e swap. Should be a busy time.
1966Stepside is offline
Old 03-22-2011, 07:53 PM   #2740
alwaysbroken
finished painting the underside of my new box
chevys the way to go.
alwaysbroken is offline
Old 03-22-2011, 07:59 PM   #2741
mudderphil
just sat in the truck and preatended that i was out cruising
Old 03-22-2011, 08:27 PM   #2742
rendus
rendus's Avatar
I put a skim coat over the left fender patch panel I welded in recently. And long boarded it smooth. If it looks good enough tommorrow morning I'll go ahead and shoot it with epoxy primer.
Next step: Driver's side rocker and floorboard
rendus is offline
Old 03-22-2011, 08:34 PM   #2743
jbgroby
jbgroby's Avatar
I needed to remove the adaptor off the steering column so the painter can get her painted and I can mount it. I had two of the correct length bolts and needed a 3rd. Wouldn't you know it that all I had was 1 6" bolt. Well Neccessity is the Mother of Desperation. Anybody else got creative with a tool?
jbgroby is offline
Old 03-22-2011, 09:16 PM   #2744
Bugeyev8
Bugeyev8's Avatar
I would have stacked a few sockets on there before I used the washers...but hey it worked right ?
Bugeyev8 is offline
Old 03-22-2011, 09:31 PM   #2745
Delmo
Delmo's Avatar
LOL, love it.
Delmo is offline
Old 03-22-2011, 10:04 PM   #2746
jbgroby
jbgroby's Avatar
Damn, I did not think of a socket. it took me 20 minutes to dig around and find that many washers.
jbgroby is offline
Old 03-22-2011, 10:18 PM   #2747
knuckledragger
knuckledragger's Avatar
Installed the oil and temp gauges,set the fan controller temp,built the throttle linkage,adjusted the carb.Got the new plates and registration.prepped the last vent window and painted it.
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline
Old 03-22-2011, 10:18 PM   #2748
Real_McCoy
Real_McCoy's Avatar
Christian and I sat the new seats in the 66 for a test fit. Christian is liking them as evident in the pic.
Daniel
66 Chevy C10 LWB
Support our troops!
Old 03-22-2011, 10:18 PM   #2749
BigCarter
BigCarter's Avatar
i cant win this fight with the picture i have in my head of what i want my truck to look like so i finally gave in and oredered a drop crossmember and im going to go ahead a bag it. so time to start cleaning everything up, disassemble and get ready for parts to start arriving.
BigCarter is offline
Old 03-23-2011, 12:00 AM   #2750
Touchdown67
Touchdown67's Avatar
Finally have the paint in order and had the engine and drivetrain introduced to the chassis.... I can see the light at the end of the tunnel.....
Touchdown67 is offline
Closed Thread
