03-21-2011, 04:49 PM | #1 |
Moderator
Air tool woes
I have a nice 60 gallon / 5hp / 220v compressor. I bought it lightly used, replaced the pressure switch, belt, changed the oil and now it's in top shape, quickly fills the tank up to about 120 psi where I have the cut-off set and does everything else a compressor should quietly and efficiently.
Directly from the tank I have a 3/8 ball valve to about 75' of quality 3/8 goodyear hose. The problem is that my air tools are so weak they are useless. They have no power, I can stop a ratchet or drill with my hand. It's not that the tank is quickly depleted because I could run a cut-off wheel for a couple minutes before the pressure goes down to around 95psi where the compressor kicks is. I'm wondering if the size of fittings/hose I have are too restrictive? Could the 75' of hose be too much? It feels like the hose fills up and "absorbs" much of the pressure, I get a short blast of power, then weakness. It seems like a volume (CFM) issue more than pressure and supply? I think I'm answering my own questions but before I throw $$$ at it I'm wondering if you all have any thoughts?
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-21-2011, 05:14 PM | #2 |
~Rest In Peace~
Re: Air tool woes
first of all i would get a water/oil seperator ,water will ruin air tools quicker than panties coming down on prom night ,
air tools take alot of air to run at top speed i dont think your compressor is big enuff
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
03-21-2011, 05:28 PM | #3 |
The One And Only !!!
Re: Air tool woes
IMO the 75' hose is what's killing you more than the size compressor, Try a shorter 25' hose and see how your tools react to that.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
03-21-2011, 05:29 PM | #4 |
Moderator
Re: Air tool woes
Forgot to mention, I do have a water separator, it's kind of on the small side though could be a bottleneck...
I wish I had a 2 stage 80 gallon but I don't see any reason a 60 gallon shouldn't run say a 3/8 wratchet? Plenty of shadetree guys like myself using them.
03-21-2011, 05:36 PM | #5 | |
Re: Air tool woes
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
03-21-2011, 08:15 PM | #6 |
Registered Cruiser
Re: Air tool woes
What do you have for a regulator? That compressor should almost run a jackhammer.
I intend to live forever. So far, so good. |
03-21-2011, 11:03 PM | #7 |
Moderator
Re: Air tool woes
Picked up a bigger regulator today and some high flow quick-connects. I'm going to try 25' of hose, the bigger regulator and better quick connects. I'm also thinking about removing all of the fittings and making sure they aren't mis-fabricated, as in the holes aren't fully drilled.
03-21-2011, 11:31 PM | #8 |
Re: Air tool woes
A 60 gal. should run most anything, providing the pump is large enough. (imo, I'm one of those shadetree guys.) Sounds to me like a flow problem.
I'd look at the plumbing first. I ran 1/2" up to the regulator, 3/8" to the water separator, and 1/4" quick connects for the line. I don't feel your 75' line is the problem unless it's broke down inside or has something like a rock in it and blocking the flow. If I need more hose, I don't have a problem adding another 50' length to mine. Separator could be your restriction. esp if it's one of those separator/dryer combos. I've got a couple of the small ones that Home Depot/Lowes sells, one off of the tank (just past the regulator) and I'll plug the second into the line somewhere if needed. I also run a few drops of air tool oil in my tools before I use them. I'm not a painter, but can run a cheap DA, needle scaler. or die grinder if I want to. Smoke break and slow typing got you in first, lol
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 03-21-2011 at 11:32 PM. |
03-22-2011, 11:53 PM | #9 |
Re: Air tool woes
I got a craftman seperator on my tank then if i want a smaller one ill put right before my impact. My compressor tank is smaller but mine goes up to 155 and i run my guns around 120 and it works great for what i need.
1969 Chevy c20(Miss Hackjob) |
03-23-2011, 12:58 AM | #10 |
Getcha Pull
Re: Air tool woes
I'd set the cut off higher myself... The shop I work in is set to 155. I consider 120 low. When I hit 120-110 you can just feel the power lose in the tools.
I would start ripping things out of the system to try. First the separator, then the regulator, and finally the long hose. I'm sure you'll find your problem there somewhere. I run roughly 20' 3/8" hoses, and have a second that I can plug into the first if I need the extra length. I also have two outputs. One through a regulator/drier and another straight from the tank with no real noticeable difference. But I also have a overkill regulator.
'81 K10 454/SM465 '86 S10 Blazer '95 H-D Softail '96 Integra |
03-27-2011, 10:41 PM | #11 |
Moderator
Re: Air tool woes
I figured it out, the quick connect fittings weren't "fitting" so much and restricting the airflow. I inspected and tested each of my male/female fittings and found out there are like 4 varieties, and some combos would allow no air, others some air and others full flow. I also upgraded the air filter/regulator to a larger one, removed an extra hose and bumped up the pressure cut-off to 130. WOW what a difference, I ran every tool I have on hard jobs and they all worked flawlessly. I was most impressed with my right angle air drill, it zipped through the frame, making 4 holes in less than 5 minutes.
I needed to remove the nuts on my axle u-bolts (tried a breaker bar and every other trick I know) so I bought this little puppy and it zipped them right off. Advertised 625 ft. lbs of torque and gets rave reviews online. It was $77 after a 20% discount and taxes, worth every penny IMO:
