Old 03-22-2011, 11:48 AM   #1
chuckthetruck
chuckthetruck's Avatar
Stripped Lug Nut help
I am changing out my wheel cylinder...the lug nuts on my 1987 GMC sierra are ALL stripped on this drivers side. The lugs on this truck are about 5 different kinds. It has been in the family for a while..haha
I am new to mechanics and have never ran into this problem. I believe they are all chrome capped lugs. I do not want to replace them with the same. So first can you help me get them off so I can finish the job...and pray i do not snap the brake line...and 2...where can i find a good set of lugs (original or not) that I can get a whole set of them to replace all of them.
Thanks again for the help!
chuckthetruck is offline   Reply With Quote
Old 03-22-2011, 12:10 PM   #2
SeanPaintsFlames
SeanPaintsFlames's Avatar
Re: Stripped Lug Nut help
I'd say that the chrome caps are just spinning around on the nut. Try maybe drilling a hole in the top of them and prying it off with a screw driver. Then you should be able to get at the nut with a properly sized socket.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-22-2011, 12:15 PM   #3
chuckthetruck
good idea....never thought of that...the chrome cap is actually not moving...it is flattening out and rounding the nut...one of them is completely smashed in like it was hit with a hammer...
Old 03-22-2011, 12:37 PM   #4
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
if not any auto parts store should sell striped nut remover kit. these have saved my butt several times.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 03-22-2011, 12:40 PM   #5
chrismoore701
chrismoore701's Avatar
You should be able to get a cone type socket at your local auto store. take this and put it on your impact, if you have one, if not try to find someone with one. the cone will heat up and grab the nut and spin it off by friction. been a while since I used one of these, but I remember it worked. good luck
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-22-2011, 12:48 PM   #6
chuckthetruck
Thanks...i will go to the store and see what I can get. Here is what I am working with just so you have a visual
Old 03-22-2011, 02:17 PM   #7
dieseltech
you might want to pull those center caps off first
dieseltech is offline   Reply With Quote
Old 03-22-2011, 02:36 PM   #8
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Pull the center caps off. Use a flat head screwdriver to break the flimsy sheet of chrome steel off of the top of the lugnut and you'll see that the skin pulls right off.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 03-22-2011, 06:10 PM   #9
mooseknuckles
mooseknuckles's Avatar
it looks like the socket isnt going on far enough to get a good grip...take the center caps off and try it
mooseknuckles is offline   Reply With Quote
Old 03-22-2011, 06:15 PM   #10
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
thats why I love this Board always a helping hand to help another out
yes i agree take that center cap off then that will allow you to get a
socket all the way over the lug nut...
JOHNORO is offline   Reply With Quote
Old 03-22-2011, 07:00 PM   #11
justpball
justpball's Avatar
if that doesnt work buy a socket that is the metric size a little smaller then what you need and put it on an extention and hammer it on the lug...then remove, but i think taken the cap off will work.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 03-22-2011, 07:19 PM   #12
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Use a bolt out once the cover is removed. If all fails, use a nut spiltter. Break if off if necessary. Ouch. Either way, I would put in a new stud.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-22-2011, 08:55 PM   #13
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
It's one of the lugnuts with the chrome cover on it! Split the cap with a screwdriver or chisel. I had the same exact issue! Don't waste your money on easy-outs, lug nut removers and acts of god.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 03-23-2011, 12:52 PM   #14
chuckthetruck
Yeah this is exactly what I did....made me feel like a stone age mechanic chiseling.....however they are all off...thank you everyone...NOW...
I want to replace these lugs on this truck (like 4 different kinds) with all one kind/brand....what can i get that wont break my bank but NOT CAPPED?!?
Old 03-23-2011, 01:25 PM   #15
kelsfine69
18 Till I Die
kelsfine69's Avatar
I would go to your local tire shop. They carry all kinds and are sure to have replacements. They deal with lug nuts all day long...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 03-23-2011, 05:24 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
i got some at costco cheap $$
but solid steel chrome nuts not cheap cap covered ones
I've hammered on the closest size till it fits,
just don't get open ended ones again the stud will rust behind it and make em hard to get off
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-23-2011, 07:23 PM   #17
tucsonjwt
My 83 C20 had the wrong size lug nuts on two wheels on one side. I think the guys at the Costco tire shop got my lug nuts mixed up with some other vehicle's lug nuts in the same service bay when I had new tires installed. I got replacement stock lug nuts at NAPA, but they are cheaper online, especially if you are going to buy 16 of them for 2 wheels (3/4 ton 8 lug wheels). I think I paid about $3 per nut, which is way to much, IMHO.
tucsonjwt is offline   Reply With Quote
Old 03-23-2011, 09:30 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
20 5X4 i'll check the bill.........now wondering
John
