Old 03-23-2011, 11:54 AM   #1
t76turbo
Column light spade connector on fuse panel
I was reading the thread in the FAQ section about wiring a neutral safety switch for a van column and am confused on one part.
http://67-72chevytrucks.com/vboard/s...d.php?t=126579
There is a picture in that thread that shows the fuse panel with labels. One is labeled something mentioning column light. I needed to plug my gear indicator light into something since the PO never did when he put the van column in. He just left it coiled under the dash.
That spade connector on the fuse panel is hot all the time. There is another spade connector next to the cluster lighting fuse that works perfect. It dims with the cluster etc. so I just used that.
But I just wanted to know for future reference what that spade should/could be used for.
1970 Shortbed 2wd C-10
t76turbo is offline   Reply With Quote
Old 03-23-2011, 01:46 PM   #2
MickMc
MickMc's Avatar
Re: Column light spade connector on fuse panel
Watching this...
Mick
MickMc is offline   Reply With Quote
Old 03-23-2011, 02:11 PM   #3
john
member #16
john's Avatar
The cluster feed spade is correct for the tilt column light.
john is offline   Reply With Quote
