Old 03-23-2011, 11:27 PM   #1
blackedoutharley
Idea, any help appreciated
I have this idea of converting my '65 c-10 to push button start.
I suck when it comes to wiring but have an idea of what I want.
My thought is to install the push button start in place of my factory cigarette lighter.
My theory is that one leg of the current switch controls the starter when turned all the way to the right at the momentary position.
I'd like to somehow have the ignition switch become the accessory side while still being required to be turned on to power the starter button.
I am thinking something like this kit:
http://www.keepitcleanwiring.com/cat...--LED-Red-Ring
or this:
http://www.keepitcleanwiring.com/cat...n-Start-Switch
Am I out of my mind or is this a simple conversion without hacking to death my Painless harness?
blackedoutharley is offline   Reply With Quote
Old 03-23-2011, 11:36 PM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Idea, any help appreciated
Pretty simple ... turn your key to RUN, then the push button engages the starter.
Move your purple start wire to one terminal on push button, then jump the RUN hot to the other terminal. (that way the push button would only work with a key)
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-23-2011, 11:45 PM   #3
blackedoutharley
Thanks! I don't know if the wires are color coded the same with the Painless harness but I got what you're saying.
Although how do I make the ignition switch work as an accessory only without powering up the HEI?
I am not opposed to running a toggle switch also that would have to be turned on after the switch is turned "on" prior to hitting the button.
Old 03-24-2011, 01:01 AM   #4
blackmopar
thats funny i look at that cig lighter everyday and think the same thing - just way bigger fish to fry for now - im pretty sure Chief has the plan right - please post as you continue - im subscribed!
blackmopar is offline   Reply With Quote
Old 03-24-2011, 11:06 AM   #5
kieth
kieth's Avatar
find the wire on your ignition switch which goes to the starter , (it will only be hot when the key is turned and held against a return spring )
remove it, take it to the push button on the side where the circuit is completed.
(the side that is only hot when the button is down)
Hook up a 12 volt power supply from the old key switch that is hot only when the key is on to the normally open side of the new push button, voilla you can now start the vehicle with the pushbutton, but the key must be on for your ignition to operate.
kieth is offline   Reply With Quote
Old 03-24-2011, 11:52 AM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Its a cool idea. I look forward to seeing it done.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-24-2011, 12:11 PM   #7
Revoh
Revoh's Avatar
The old early-series '47 that I learned to drive on had a push button starter on the floor from the factory. It was kind of a hassle to hold down the brake or the clutch, run the starter, and pump gas through it sometimes, though.
1963 C-10
My car blog, for your reading pleasure.
Revoh is offline   Reply With Quote
Old 03-24-2011, 12:52 PM   #8
Clyde65
Clyde65's Avatar
alot of the newer cars are doing this, Nissan and some others, I think it is cool.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-24-2011, 01:44 PM   #9
Stepside65
Still Truckless!
Stepside65's Avatar
It's definitely a good theft deterrent. Can't steal what you can't start.
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 03-24-2011, 03:19 PM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Idea, any help appreciated
Poe man version:
http://67-72chevytrucks.com/vboard/s...d.php?t=402277
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
