Old 03-23-2011, 09:18 AM   #1
baclay9
Need a pic from a later model crew cab, like around 90' or so.
I need an under hood shot of the top of the motor. Truck needs to have a 454 and the large 4 core radiator that is offset to one side. Similar to the 6.2 deisel radiators.
What I am particularly looking for is the what the water neck and upper radiator hose look like. Thanks for any help.
baclay9 is offline   Reply With Quote
Old 03-24-2011, 12:48 AM   #2
pig rig
pig rig's Avatar
Re: Need a pic from a later model crew cab, like around 90' or so.
if Im right you have the big 4 core rad its longer then the regular 4core thats what was suppose to be in mine but some brain child used a rad out of a 88 an newer std cab. so piced mine together with the smaller 4core are you having problems finding the right upper hose if so I think I still have one hanging in my shop I'll grab the part# off of it for you
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-24-2011, 09:59 AM   #3
baclay9
Yes, that is the radiator I am using. What I am doing is this. I am dropping a 454 in my 1/2 ton so I wanted that big radiator to make sure cooling would be good.
I also am putting a serp setup off of an early 90's 350 on it using an adapter kit from Kwik Performance. I was wanting to see which shape the water neck and hose were on a 454 with the large radiator so I could tell if it will clear the serp setup.
