Old 03-24-2011, 09:27 PM   #1
Rumble
My TBI truck's fuel pump keeps cycling ??? Any ideas why
I didnt notice it until i lifted the truck and spent sometime underneath and i kept hearing it cycle.
anyone have this problem? or know what it could be, i bought the truck last year as a toy and havent had much time behind the wheel. So i am not sure if the PO screwed wtih anything.
thanx
Rumble is offline   Reply With Quote
Old 03-24-2011, 10:36 PM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: My TBI truck's fuel pump keeps cycling ??? Any ideas why
is this while it's running?or turned off
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-24-2011, 11:17 PM   #3
Rumble
while the key is off and out of the ignition, i expect it to run when its running, lol
i wasnt sure if you were being serious
Old 03-25-2011, 01:39 AM   #4
rfmaster
rfmaster's Avatar
Check for sticky oil pressure switch - it should have gray and orange wires (some models have brown wire used for idiot light) going into connector. Orange wire goes to battery - always hot, gray goes to fuel pump. Oil pressure switch has (NO) normally open contacts - when oil pressure is below 4 to 6 psi contacts are open and closed when higher. Oil pressure switch acts as back-up for fuel pump relay.
Some HD models were equipped with fuel module which keeps fuel circulating for 30 seconds to prevent vapor lock. If this module is defective it may keep fuel pump operating for extended period after shut off.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 03-25-2011, 06:19 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
well i was half serious,but some times it's easier to ask then guess
and i was going where rfmaster went
John
Old 03-25-2011, 12:10 PM   #6
Rumble
you guys are great, thanx for the info, i will check into it ( gotta break out the Hanes maual) to find everything,
where would that fuel module be, ( my truck is a 3500 crew "spuare body" dually )
so i think it would be considered HD, sound right?
Old 03-25-2011, 01:05 PM   #7
Rumble
i kinda suck with electical stuff, so basically if i get a voltmeter to check it then what should i expect when i check the grey , basically nothing right? no current?
sorry for the dumb questions, just gotta make sure i do it right, the truck has already killed one battery and I gotta keep the ground disconnected on the new one ( i know, reconnect it before i check current) LOL
Old 03-25-2011, 03:28 PM   #8
rfmaster
rfmaster's Avatar
Well, we all have to start somewhere. If you disconnect oil pressure switch connector from the oil switch this will disable oil pressure switch function. ECM controls fuel pump (FP) relay and when ignition is OFF ECM removes power to FP relay - opening FP relay contacts. If engine is cold and you have thick (SAE 30 or 15W-40) oil than oil pressure switch may keep FP operating for a few seconds until oil pressure drops below 4 PSI. If you still get fuel pump operation than it is likely that fuel module is malfunctioning by providing current around the oil pressure switch. You can measure DC voltage (not current) with your DVM by probing oil pressure switch gray wire with one test lead and the other lead tied to ground. Alternatively, a 12V test light can be used to verify if the switched end of fuel pump circuit is receiving power from FUEL MODULE. The 1 ton is defiantly HD in my book so its more than likely that it was equipped with a fuel module.
If cycling stops after you disconnect oil pressure switch connector - it is likely than not that oil pressure switch is sticky....
I have attached a schematic of C/K fuel pump control circuit (bottom of the page). Main control over fuel pump is provided via FP relay with oil pressure switch providing a backup in case of FP relay failure. On HD models, if equipped with fuel module, a third control element provides power to the fuel pump only when ignition key is ON position (unless PO hacked the harness)! From what I have seen fuel module keeps fuel pump operating for about 30 seconds after ignition has been shutoff.
//RF
"The Beast"
