Old 03-25-2011, 02:59 AM   #1
dropped81
dropped81's Avatar
Overheating problem please help!
Okay guys I'm new here and really need some help on figuring out why my trucks temp gauge fluctuates. I can drive for about 10 min and the truck will be around 230 degrees. Than all of a sudden the temp will drop down to about 205. I have a 195 thermostat in it i just replaced. also just replace the radiator so i know its not that. Water pump looks fine from what i can tell don't see any leaks. I'm gonna try a flush tomorrow to see if maybe there's an air bubble. Any help is much appreciated. Thanks Mike.
dropped81 is offline   Reply With Quote
Old 03-25-2011, 03:01 AM   #2
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Overheating problem please help!
Mine does the same but not as high....Sounds like the thermostat to me....Its reacting slowly.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 03-25-2011, 03:05 AM   #3
dropped81
dropped81's Avatar
i just replace the thermostat its the second one in about 6 months. I'm kind of wondering if it might be my coolant to water mixture i know it can cause your truck to overheat. and its not overheating severly.
Old 03-25-2011, 05:52 AM   #4
donut
donut's Avatar
Any steam rolling out? How accurate are the gauges?
Mine will spike a little high, then drop back when the thermostat opens. As long as your coolant is close to abt. 50/50, that shouldn't be an issue.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 03-25-2011, 06:02 AM   #5
Pop's C-10
Pop's C-10's Avatar
fan clutch maybe?
Pop's C-10 is offline   Reply With Quote
Old 03-25-2011, 08:22 AM   #6
chrismoore701
chrismoore701's Avatar
2nd the fan clutch. are you sure you have the right radiator. I think they come in 2, 3, and 4 cores. good luck
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 03-25-2011, 08:27 AM   #7
hatzie
Moderator
hatzie's Avatar
If you're not blowing out steam you may want to verify the actual engine temps.
Factory gauge senders aren't always accurate especially after 23+ years.
If the temps are real then start by checking the clutch fan operation and how much crud is in the radiator.
hatzie is online now   Reply With Quote
Old 03-25-2011, 10:07 AM   #8
Eyegore
What Hump?
Eyegore's Avatar
You may also want to consider the water pump, it seems you have a restriction somewhere. In my 86 in stop in go traffic it never overheated but when i ran it down the freeway at higher rmp then it would overheat. Also when it begins to heat up kick on the heater and see if the bypass into the heater core cools it down.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-25-2011, 10:42 AM   #9
JBRAVO383
JBRAVO383's Avatar
Has the water pump been replaces recently?
on my 85 There was a v-belt water pump on my 383 when i was running a serpentine set up. In-which a serpentine set up runs the opposite way a than a v-belt set up. But my temps were fluctuating 185-225 and when i would rev it up my upper radiator hose was being sucked shut.
This may not be your problem but just something to look into.
Thanks,
John
85' c10 swb 383 th400 ran:
13.26 @ 99 w/ a 1.8 60'
JBRAVO383 is offline   Reply With Quote
Old 03-25-2011, 10:51 AM   #10
jrcaprai
Do you have a Fan Shroud ???
jrcaprai is offline   Reply With Quote
Old 03-25-2011, 03:52 PM   #11
dropped81
dropped81's Avatar
Thanks guys for all the responses. no steam is rolling out and the gauges are dead on accurate they are aftermarket not stock. Chrismoore701 and pop's c-10 i know the fan clutch has a bit more play in it than it should but its still working fine for now its on the list of things to fix, but also would the fan clutch cause the temp gauge to fluctuate like it is. Also chrismoore701 i didn't even think about the radiator rows. I think you might be on to something my old one was a 2 row and my new one is oly 1 row and none of this started until i changed the radiator. even when it had a pretty good sized leak in it the temp still never got hotter than 195. and yes there is a fan shroud i ran with out one for about a week and realized i should probably put it back on i didn't realize it made as big of a difference as it does lol.
Old 03-25-2011, 04:40 PM   #12
Eyegore
What Hump?
Eyegore's Avatar
I know were only a couple of days into spring but how hot where you are at? If the probleml started after you installed the one row, it sounds like that radiator has some sort of restriction in it. I would take the lower radiator hose off and run water through it to see if it frees something up.
Lil red 86 c-10
99 Sub
Old 03-25-2011, 05:46 PM   #13
dropped81
dropped81's Avatar
I just did a flush on it and nothing came out and the weather here is still a bit chilly but the truck is still getting up to about 230 or 235 than dropping down too about 205-210. I think it has something to do with this radiator.
Old 03-25-2011, 05:48 PM   #14
dropped81
dropped81's Avatar
Also my passanger side floor is dry but do you think it could be something in the heater core?
Old 03-25-2011, 07:27 PM   #15
85Bowtie
85Bowtie's Avatar
It sounds to me like you have air in the system. Are you sure you're getting all the air out? What you will have to do IIRC (been a long time since I looked under the hood of mine) is jack the front of the truck up so the radiator is above the intake. Open your radiator cap and run the truck up to operating temp with the heater on high. Any air in the system will go to the highest point, which is at your radiator cap.
Is the overflow filling up at all? If so, you may have a bad head gasket. If it is a small leak on the cylinder side, the pressure from inside the cylinder is enough to keep the coolant from running into the cylinder. Instead, it will push air/exhaust into your coolant system because of the greater pressure. This will displace t he coolant in your system and give you an air pocket which does exactly what you're describing. If so, when you have the heater on you would notice it blowing cold all the sudden.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 03-26-2011, 04:14 AM   #16
dropped81
dropped81's Avatar
Thanks for the info 85bowtie ill check it out tomorrow when i get some time.
overheating
