Front End Swap
Can anyone tell me, Is there a lot of fab working swapping the front suspension and brakes from an 87 chevy to a 69 c-10, I mean if I get everthing off the 87 will it bolt/weld into the 69 without a ton of work.
Thanks for any help
2008 HD 2010 Camaro 2ss (The Wife's Ride) 2005 Suzuki GSX-R 1300 "Busa" 1969 C-10 (under Construction) 2013 Sonic LT "LIVE LIFE,TASTE DEATH" |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Front End Swap
Welcome to the board.
You might look here,... http://67-72chevytrucks.com/vboard/s...68&postcount=4 You have picked a question that gets asked here daily. There are may build threads that show how easy it is to swap the front to disc brakes.
Re: Front End Swap
thanks
Re: Front End Swap
Does this info include 1 ton trucks? I have a 69 C 30 flatbed I would like to upgrade to discs.A wheel up grade also,not wanting the split rims that came on it. Thanks. Muley
#5 | |
Re: Front End Swap
I would use the 73-87 1-ton donor truck for your parts. If you want drop spindles,... they will also have to be for a 73-87. (the aftermarket doesn't make a "direct bolt-on" spindle for the 67-70 1-ton trucks, like they do for the 1/2 ton trucks.)
Re: Front End Swap
lolife99,will the 73-87 parts swap to my 69 front end or am I needing the complete front suspension? I know about 1/2 ton swaps,Ive just gotten the c30.Thanks for any advice. Muley
