Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork > Detailing
Old 03-25-2011, 09:09 PM   #1
1425956
1425956's Avatar
Good chemical to remove glue and trim.
I just purchased an 84 GMC SWB and the trim on it was faded badly and needed to come off. I have used Castrol Super Clean in the purple bottle many times for cleaning and de-greasing, so I decided to give it another try. I had pulled one piece of trim off already and was getting ready to take a razor blade to the left over glue/tape. I sprayed it down with Super Clean to remove the excess dirt and minimize scratches.
Well, as soon as I wiped it with a rag, I noticed the glue had almost turned to a gel. So I went all the way around the truck and sprayed the rest of the trim to let it soak before I pulled it off. I let it sit for about 10 minutes and the trim pulled/fell right off! Just a little more cleaning and wiping, and a little razor blade, and the truck looked ten times better. I rubbed a little cleaning compound on the paint where the trim used to be and it came very clean.
Works great on engine detailing as well. Just wanted to share with everyone.
1425956 is offline   Reply With Quote
Old 03-25-2011, 11:59 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Good chemical to remove glue and trim.
Energine works well, but I'm not sure how it would react on paint.
Glad to hear it worked for you.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-26-2011, 12:01 AM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Never woulda guessed that, I would've went straight to laquer thinner LOL
John
1999 Toyota Tacoma 4x4
Old 03-30-2011, 01:06 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I normally use 3M adhesive remover, or PrepSol.
(both are great wax and grease removers also)
Recently I had removed some old door edge guards from an original paint truck.
It appeared that the door edge guards were installed with a very hard adhesive,... almost like contact cement.
No chemical worked on it.
Then I purchased a 3M eraser wheel that is used with a standard drill.
It worked great.
They are kinda pricey,... but it saved my original paint!
Check them out here:
http://solutions.3m.com/wps/portal/3...beSQSFJR0R56gl
Keith
Convert to disc brakes.
Old 03-31-2011, 01:47 AM   #5
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
It worked great.
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 03-31-2011, 12:53 PM   #6
wiggins
wiggins's Avatar
I could use one of them on a project right now. Where did you get it from?
It worked great.
Preserving American History one truck at a time.
wiggins is offline   Reply With Quote
Old 03-31-2011, 12:58 PM   #7
lolife99
lolife99's Avatar
I got mine at a local auto parts store.
Anyone that carries 3M paint products.
They're about $40 but they last a long time.
Keith
Old 08-17-2011, 11:26 AM   #8
big_al_71
big_al_71's Avatar
Guys a secret of the trade is to use a valve stem with an electric drill to remove any kind of glue or adhesive.
attach the valve stem to the drill from the threaded side into the chuck and use the drill on slow and with the rubber side of the stemm the part that would normally be insode the wheel rub off all the glue, adhesive etc.
then wipe it with ACRYSOL and you are done. I have ownder many chevy 1500 and the first thing we do is remove all the black trim moldings doing it this way it literally takes me 15 minutes to do the whole truck.
http://www.helmsmotorsports.com/apps...s/show/1931302
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-05-2012, 11:32 AM   #9
Smoke_Dog
Smoke_Dog's Avatar
Location: Hickory, NC native, but stuck in Valdosta, Ga
How about to remove weather stripping glue, what do U use?
Smoke_Dog is offline   Reply With Quote
Old 01-05-2012, 01:47 PM   #10
wiggins
wiggins's Avatar
3M adhesive remover and elbow grease
