Old 03-26-2011, 08:26 PM   #1
DaBigKahuna
DaBigKahuna's Avatar
Side Marker lights...
Got a question for you guys.
I just noticed that when my headlight are on, my front side markers flash with the turn signal. Seems to me that on a '71 they should just be lit and not flash. I'm wondering if the PO might have wired it up funny.
DaBigKahuna is offline   Reply With Quote
Old 03-26-2011, 08:40 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Side Marker lights...
no, they are supposed to flash
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-26-2011, 08:41 PM   #3
Gene
Gene's Avatar
posted via mobile device
x2
Gene is offline   Reply With Quote
Old 03-26-2011, 08:57 PM   #4
DaBigKahuna
Thanks for the quick answers!
Now i gotta figure out why they flash too fast ;-)
Old 03-26-2011, 09:18 PM   #5
Gene
Gene's Avatar
Prob bad or wrong flasher. Try a new one, they are cheap.
Old 03-26-2011, 09:20 PM   #6
hayhauler71
hayhauler71's Avatar
bad bulb
wrong bulb
missing bulb
flasher
here are a few things to look at
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 03-27-2011, 01:24 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
most flashed, but not all of them.
Old 03-27-2011, 01:56 AM   #8
DaBigKahuna
Thanks for the ideas. I thought I remembered that the flasher would go faster with a higher load and slower with a lesser load like from a burnt our bulb. I swapped out both front bulbs today as I added clear lenses with amber 1157s and that made no difference in the flash rate.
I think I'll look at the flasher since it's faster on both left and right. If it was a bulb, it should affect one side.
Old 03-27-2011, 02:25 AM   #9
doctrouble
doctrouble's Avatar
Sorry, don't mean to take over but, i have a similar problem. (none of my side lights show life.) One of the front turn signals burnt out and replaced it. 2 secs after i tried the turn signals it went out again. The other side is still fine tho..
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 03-27-2011, 02:29 AM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: Side Marker lights...
I'm converting all my trucks at have side makers to flash.Most people are to busy on the phone to pay attention to you.And are trucks are so poorly lit up I need all the help to let people i'm turning. Kinda wish the rear did it to.But i see they only had that option in 1971--72 Not to sure if they hand it in the more Deluxe trucks But i see it as a added bonus.i"m not one for guys shaving there side markers.its a safety device.sence trailer have them there has to be a reason why the federal government wanted them on the side of are trucks and car;s after 1967.To bad a few friends of mine had to figure that one out the hard way.Friend of mine was pulling out of a dark lite side road and the guy Hit him Brod side spoune him around and another car T boned him Just destroyed that $15,000 doller truck it took him over 10 years to build it.He later admitted if he would of had the side makers the guy would of honked his horn.He got sited for pulling out onto on coming traffic.
I do understand that most of us want to customize are trucks and car's.But leaving out the safety options is a Big risk on the builders and the owners.I'm all about safety I saw them New LED lights in a 1970 chevy truck to day.There way Brighter then i though they would be and They really got my attention when traffic abrumpley stopped. Man i need to get a set for my trucks.
stsalvage is offline   Reply With Quote
Old 03-27-2011, 02:35 AM   #11
stsalvage
Scrapper 1
stsalvage's Avatar
It might be time to buy a new front Light harness there 125.00 But if you go that far your should really start buying the engine wire harness as well to much is riding on them 35 year old wires that every moron has cut added or just planed messed up.You get new wiring gutters New plug's and New Dia electric grease and it makes your head lights brighter and less chance of a short and a fire under the hood.look Up this web side WWW.TRUCKANDCARSHOP.COM THEY USE THE m&h RE POP FACTORY HARNESS AND IF YOU WANT YOUR SIDE MARKERS TO BLINK USE THE 1971--72 FRONT LIGHT HARNESS
Old 03-27-2011, 03:15 AM   #12
doctrouble
doctrouble's Avatar
Thanks!! Another free!! catalog i can browse through. Ya, almost everything i'm seeing is home-twisted with electrical tape Exa: found a constant hot wire just hanging down from under the dash... (just have to say how much help you guys are and how much i love this site)
1970 Cst - 20 402
Old 03-27-2011, 10:11 AM   #13
Transformula
Transformula's Avatar
I figured out how to have either "Steady on", or "Flashing" side markers, and it only has to do with how the side marker is wired. Here's how:
For a steady on application, wire the side marker so that one lead goes to ground and the other lead ties in to the front "running light" circuit, the one that powers the front bulb on the low, non-turn wire, usually brown.
For a flashing application, wire the side marker leads to the two hot wires of the front turn signal, and neither side marker lead goes to ground. When the headlights are off, the side marker will flash on and off in conjunction with the front turn signal. When the headlights and running lights are on, the side marker will flash on and off oppisite the front turn signal!
Hope this gives a little insight for anyone who might want to do some wiring!
T.Y.N Custom Works..... Because "Stock" Sucks!
1971 K 10 GMC Long Bed
1977 Formula T/A Frame off Resto-Mod
1995 FXDL Harley Low Rider
1985 C10 ShortWide 91 Burb front.
Transformula is offline   Reply With Quote
Old 03-28-2011, 06:37 PM   #14
elf w/capital T
Can you make it so the fender lights blink with headlights on at the same time as the bumper lights??
i want it the same blinking action even with head lights on....possible??
elf w/capital T is offline   Reply With Quote
Old 03-28-2011, 07:08 PM   #15
Transformula
Thumbs up Re: Side Marker lights...
Might be possible with some relays, but I'm not sure. GM vehicles usually have the front and fender flashing opposite each other when the headlights are on. Keeps the wiring simple I guess.
But, anything is possible with a little experimentation!
Old 03-28-2011, 07:44 PM   #16
DaBigKahuna
Now you guys are gonna make me look. I didn't pay attention to see if they flashed together or opposite.
Old 03-28-2011, 11:16 PM   #17
Longhorn Man
with the parking lights off, they will flash together.
Once the parking lights are on, they will flash oposite of each other.
Old 03-29-2011, 04:32 PM   #18
DaBigKahuna
Yep sure enough! 'course I'm sure Longhorn Man already knew!
