Old 03-26-2011, 09:12 PM   #1
tc4x4
tc4x4's Avatar
One Ton after market conrol arms
Are they out there, are they different than half tons. Whats there for stock ride height. I'm not to familiar.
tc4x4 is offline   Reply With Quote
Old 03-27-2011, 03:17 AM   #2
pig rig
pig rig's Avatar
Re: One Ton after market conrol arms
not a lot out there air ride makes some then theirs a few small shops that will make them to order
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-27-2011, 07:09 AM   #3
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I'm told the 1/2 ton upper's will work if ya swap to 1 ton ball joint. not sure if the lower ball joints can be swap'd out. I have a set of upper's and lower's, I reckon if the lower ball joint wont swap out I'll have a machine shop rework em to acceop the 1 ton ball joint.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 03-27-2011, 10:38 AM   #4
pig rig
pig rig's Avatar
the lower balljoint is a lot larger and it wont fit in a 1/2t you'll have more money in reworking them the a new set would cost to build
Old 03-27-2011, 10:40 AM   #5
D.FENS
Porterbuilt makes a really nice deal, that comes complete with cross-shafts, bushings, and upper / lower balljoints. Definitely not free but even the cheapest tube a-arms ain't really cheap.
Their arms center the wheels in the wheelwell, I guess this is mostly for looks but might also help with tire clearance if you drive around all aired out all the time. They can also make them shorter or longer than stock, depending on what brakes and hub / rotor combo you're using.
D.FENS is offline   Reply With Quote
Old 03-27-2011, 11:16 AM   #6
78cheyenne292
i just put a new lower control arm and ball joint on my 3/4 ton it was all brand new aftermarket it cost me 170 for the hole package ready to install!!! i found them at the local speed shop so im sure you could find one for a 1 ton.. and i had a lca from a 1/2 ton on for a while with a balljoint for a 3/4 ton and it worked fine
78cheyenne292 is offline   Reply With Quote
