Moderator
![]() Join Date: Jun 2008
NOS Black Shoulder Belt Set on Ebay...Not mine.
here is a set of black NOS shoulder belts on eBay right now. They are for a truck, they are GM, but they appear to be Newer GM brand NOS. You can tell by the 5-band webbing and the non dimpled male buckle retaining boots. Also, the retaining boots may be a bit longer than the 1967-70 or the 1971-mid 70s. I can't quite tell, but it looks like it. Nevertheless, they are a nice find, for someone wanting to add this rare option to their ride. I thought I'd let some of you know incase someone's looking.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 03-25-2011 at 11:29 PM. |
![]() Join Date: Apr 2001
Re: NOS Black Shoulder Belt Set on Ebay...Not mine.
Good looking out! that is what this forum is all about.
thanks. |
Roadtrip!
These are also being discussed on the message board. More info there...
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() Join Date: Jan 2004
Richard, That is where my little brother purchased his NOS seatbelts from. They are too rich for me right now. Last I saw $430. Mike.
#5 | |
Moderator
Yes, they are getting up there. I paid around $400 for my set, which has the correct 71-up dimples. These do not. Honestly, at these prices, I'd use car middle bench seat belts and purchase the boots from the Corevette reproduction websites to make a set for less. One reason being is that the buyer is already going to have to buy a new GM licensed buckle cover. If they were in the 200s, probably would be worth it. I bet they fetch over $500, though.
70 Longhorn CST Build Adding an AM/FM Decal |
VA72C10
![]() Join Date: Mar 2008
Good info on the option for the car bench seat and corvette covers....might look good in my super.....
#7 | |
Moderator
That's the route I'd go. If you decide to, I can set you up with some console seat belt retainers for the shoulder belts. I have a few more sets.
Richard, So all I need to find is another NOS middle belt like the ones I bought from my brother and make shoulder belts? Mike.
Parts Hunter
Shoulder belt length is different from middle car belt length, I believe. Also if you want to get nit picky the pass car middle belt has a wavy floor mount and the correct truck belt has a flat (66-67 gm pass car) mount. I had an original set from a 72 that I documented all the stuff from so that I could have a set made for my 67 that was dead nuts correct.
1968 Chevelle 300 DLX (350 4 speed) 1984 GMC 2500 6.2, 700r4 work truck 1967 GMC Custom (was 6.5 Turbo Diesel powered) My ebay Store: http://stores.ebay.com/The-Musclecar...3aFQ3aSTQQtZkm My website:http://themusclecarshop.net/ 1967 GMC 6.5 TD conversion build:http://67-72chevytrucks.com/vboard/s...d.php?t=290922 Last edited by mal68ibu; 03-26-2011 at 09:45 PM. |
#10 | |
Moderator
VA72C10
Could you post the info on the ends/exact dimensions here? Would make a good FAQ post for future reference. Also, I have a local guy with GM webbing who makes belts for a reasonable price. and I have a box full of faded belts with good male and female ends so I'm considering having him make me a good shoulder belt set.
#12 | |
Moderator
Moderator
Wow! Those belts are going for $610 with about 12 hrs to go. Hmmm, lets take a new guess...$750 ending?
VA72C10
craziness....guess I should make a few sets up and post them on ebay, huh
#15 |
Moderator
Definately!
#16 |
Moderator
Ok, I got some pictures and measurements.
When comparing my NOS truck female lap belt with the NOS shoulder female belt, there is only a difference of 1 & 1/2". The female shoulder belt is a little longer (1&1/2"). Therefore, any truck lapbelt should be just fine to use for the shoulder belt. The female truck lapbelt measured (webbing only) tip to tip, 42".
#17 |
Moderator
Ok, now for the male end. I measured my male shoulder belt (metal end to metal end), and it measured 28". So, a if using a car middle belt, it would have to be between 25-32 (metal tip to metal tip) inches to work. However, if piecing these together, all you need is the correct flat ends and any male belt that has webbing that exceeds 32 inches, and then have a shop sew on the correct flat pillar end. The waved/ridged car end will work...and you could even flatten it in a press or heavy duty vice.
Or, you could take the floor mounting end from a Female doner truck lap belt, and make the needed cuts and make one exactly like the flat truck male shoulder belt.
#18 |
VA72C10
Great info!!! Thanks for posting!!!
#19 |
Moderator
Ok, I was off by $40. They ended at $710. That should be a good enough reason to want to make your own using the corvette boots
#20 |
Born Psycho
![]() Join Date: Feb 2001
someone wanted them really bad
my first set of black ones was made up with corvette belts and boots with truck hardware. i have another set of oem out of a suburban that need restoring. after seeing how much those went for, i guess it's worth restoring mine.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
#21 |
VA72C10
so where is everyone finding the corvette boots? I've searched google and ebay and haven't found them...
#22 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
You have to look them up on corvette parts distributors. I think they call them end covers. They will somewhat look the part, but for any truck with the window down driving, the belts will be blowing around banging into the rear cab walls. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever Last edited by 71blksuper4x4; 03-27-2011 at 07:42 PM. |
#23 | |
Moderator
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 03-28-2011 at 01:23 AM. |
#24 |
VA72C10
Awesome! Thanks.
That's pretty cheap. I can make a set that looks like the one on ebay for $107 then
#25 | |
Moderator
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 03-28-2011 at 01:42 AM. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
