Old 03-27-2011, 02:09 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
Spindle nut will NOT come off!
It's on a 1980 GM 10-bolt 6-lug... The driver's side seems to have never been apart, and came apart with no effort. The passenger side has to have been apart because two studs are replaced, and I can NOT get the spindle nut loose. I've even torched it. Any other ideas? I'm totally stumped.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 03-27-2011, 02:15 PM   #2
sandking
.....I am working on it.....
sandking's Avatar
Re: Spindle nut will NOT come off!
Reversed threads?
View my build thread HERE
sandking is offline   Reply With Quote
Old 03-27-2011, 06:11 PM   #3
Psycho71
Psycho71's Avatar
I don't recall mine (10bolt 8 lug) having left hand threads. I had to put the spindle socket on the nut and whack it a few times with the BFH, then mine both broke loose. I was scared I was gonna break off the little tabs on the $15 socket, but it took surprisingly more abuse than i thought it would.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 03-27-2011, 08:41 PM   #4
Altec
Getcha Pull
Altec's Avatar
Have you used a impact? The biggest impact you have access to, or the biggest breaker bar you can get with a 8' section of pipe over it. One way, or another something is going to break... Some Blaster never hurt too.
Last resort is to use a cut off wheel and start grinding a slit into it. you shouldn't even have to get all the way through it. Just most of the way, and the nut will stretch at the groove making it easy to loosen.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-28-2011, 02:37 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I had one that was melted on. It must of been run without grease (not by me). I hammered the spindle nut socket in place and put a 1/2 impact gun on it. Forward..reverse...forward....reverse...PB blaster, repeat. It came off real slow, but it came off.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-05-2011, 10:57 AM   #6
Rogue_Alphonse
Yeah I used a breaker bar, 4 foot pipe, had someone hold the whole apparatus as tightly against the nut as they could, and smacked it with a BFH.... no luck. The socket took no damage, but the nut did.
Old 04-05-2011, 11:03 AM   #7
Rogue_Alphonse
Hmm, I guess I'll be borrowing my dad's Dremmel then
Old 04-05-2011, 11:06 AM   #8
Rogue_Alphonse
This one doesn't look melted and spins normally, but like I said it has been apart before so it could have been put back together with no grease... I guess I can be glad this axle's not getting bolted into anything.
Old 04-05-2011, 11:14 AM   #9
OLDCHEV4X4
OLDCHEV4X4's Avatar
You live in Gap? As in rt 30 and rt41?
I live in Wagontown.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 04-05-2011, 01:39 PM   #10
Rogue_Alphonse
Yep! I sorta know where that's at.
