okay,
I have a 1986 gmc with a 305/350turbo trans (long bed) I want to pull motor and trans out and put it into a shortwide to turn into a show truck (the 305 has sentimental to me) I have found another truck same year as mine but shortwide that i can get, but i have also found a 92 chevy with a blown up motor. Both had v8s in them would mounts be a problem? is the only thing going to be different with them is styling or is there more work to be done with the 92 for my motor to work? ![]() |
Plays with trucks
Re: motor swap question
No difference between them at all.
And WELCOME.
Gary My Dad's Old Truck 1985 ![]() |
![]() Join Date: Dec 2010
305's are not "terrible" motors for a daily driver & can even be stroked. Of course they aren't as nice as a mild 350, but if you already have one & it means something to you then build it man! Just be sure to do some work to the heads to increase the flow - that's the big choke point on those engines! And like he stated - all the SBC's have basically identical mounts & accessories.
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
the 305 is out of my first truck (75 Scottsdale shortwide) i totaled the truck out and thats all i have left from it really
and thanks Last edited by darynblaylock; 03-28-2011 at 12:05 AM. |
#6 | |
Go Hard or Go Home!
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. ![]() Some day's, it's just not worth chewing through the restraints................................ |
Are you sure you can clear the bores with 2.02s and 1.6s? The stock bore is 3.736. The valves themselves take up 3.62 and add the spacing between.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
Good point & no - 305's do NOT need 2.02/1.60 valves.... Heck, some 350's don't even need that depending on application & actual head flow... If I did ANY valve work on a set of 305 heads it would of course be the quality valve job (3 angle is MORE than adequate) & maybe a slightly larger exhaust valve only since they are quite small on this head. Other than that just do a little port matching & maybe a little bowl blend & you'll be good.
#9 | |
Go Hard or Go Home!
