Old 03-28-2011, 09:02 AM   #1
blackbeaSSt
rear view mirror fell off!
came out this morning and the dern thing was laying on the floor
it left all the stuff on the windshield of course and there isn't anything sticky to stick it back up. am i SOL on using that same mirror or can i buy some new sticky?
blackbeaSSt is offline   Reply With Quote
Old 03-28-2011, 09:03 AM   #2
71swb4x4
71swb4x4's Avatar
Re: rear view mirror fell off!
You buy new sticky. You can get it at any parts store or Wal-Mart.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 03-28-2011, 09:04 AM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
The sticky (glue) is pretty cheap. Just scrape it all off with a razor blade, clean with the provided swab, apply glue to metal piece and tape it to the windshield for a bit without the mirror on it.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-28-2011, 09:54 AM   #4
RandyP
Getting Old; Going Broke
RandyP's Avatar
We do a lot of those here in the summer months, I keep a few of the glue kits just laying around actually. Just did it on my 87 last week when the new windshield was put in. Sorta chapped me the new glass did not come with a mounting tab already on it.
Put some tape on the outside of the windshield to mark where your old tab was glued (real easy if your old residue is still there). Clean the inside really good and use a razor to remove all the old glue residue. The glue kit comes with glue and activator, the activator is usually in a cardboard tube and a soft tip (like a marker). Rub the activator on the glass, wait a few moments and put the glue on the mounting tab (be sure you know which way the tab goes, installed backwards or upside down and you'll be sorta pissed). Put the tab on and put a piece of tape on it to hold it in place. Let it dry several hours or over night, slide the mirror on and tighten up the set screw and you're done!
The kits cost like $2 or something at NAPA, O'Reillys, Advanced or WalMart.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 03-28-2011, 10:30 AM   #5
blackbeaSSt
thanks guys! i guess the guy that replaced my windshield recently didn't do a good job
Old 03-28-2011, 10:48 AM   #6
tucsonjwt
I did it twice on my 83. The second time the mirror fell off it took the bracket and and big chunk of the windshield glass with it. I now have my rear view mirror mounted to the trim piece on the headliner with a big sheet metal screw - crude but effective.
tucsonjwt is offline   Reply With Quote
Old 03-28-2011, 12:56 PM   #7
jchav62
1962 C-10
jchav62's Avatar
I went through that last summer. I battled with the cheap sticky back tab that they sell at Walmart...didn't last, bought some cheap glue for mirrors, didn't work. My co-worker does window tinting so he has to deal with the tabs now and then. He lent me some glue that he bought from a dealership. I believe the can just had a part number on it and a label - "Rearview Mirror Adhesive". A good cleaning, a 'primer' and two drops... problem solved.
It's sold at dealerships only, it's not too cheap, but it does the job. Luckily for me, he already had the can and had no problems with giving me a couple drops...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-29-2011, 02:30 AM   #8
DBLSPRT68
DBLSPRT68's Avatar
Over the years, mine has fallen off several times. It seems that auto parts store glue isn't good enough for my mirror. I might look into the dealer route, cause mine is laying on the seat again.........................
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 03-29-2011, 02:39 AM   #9
bigwheel15
bigwheel15's Avatar
I must have tried 3 or 4 different glues for reattaching rear view mirrors and mine wouldnt stay for more than a few days at best. Ended up using some two ton epoxy and its now been holding for several months. Might be an idea?
bigwheel15 is offline   Reply With Quote
Old 03-29-2011, 03:57 AM   #10
78 Big10 454
78 Big10 454
78 Big10 454's Avatar
I can't tell you how many times my mirror has come un-glued. I finally bought a 71 Chevy P/U mirror that affixes with screws to the inside cab. Problem solved!
78 Big10 454 is offline   Reply With Quote
Old 03-29-2011, 12:21 PM   #11
pig rig
pig rig's Avatar
Ive always used krazyglue and never had a problem
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 03-29-2011, 12:56 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
they sell a tube thing you crack and rub on cleaned window and metal tab ...no probs
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-29-2011, 12:59 PM   #13
72lb4x4
Yep, clean w/ brakleen or similar and superglue.
72lb4x4 is offline   Reply With Quote
Old 03-30-2011, 01:23 PM   #14
blackbeaSSt
well it seems that the residue that was left is a little harder to get off then just sticky remnants. a blade did absolutely nothing to it. even sprayed some goo gone to no avail. anyone think i'll have a problem using just super glue with it sticking to whats left on the windshield?
Old 04-02-2011, 07:31 PM   #15
blackbeaSSt
so im still unable to get the old residue off and of course like i suspected super glue did not hold when put on the old residue! any other ideas to get the old crap off?
Old 04-02-2011, 07:38 PM   #16
RandyP
RandyP's Avatar
The one time I had the residue not come off, I had to glue the tab on in a different location. You can put it a little to the left, right, up or down and it still function.
What happened in my case was, someone had glued the tab on to the glass with something stupid and it ate in to the glass but would not totally adhere to the metal tab.
Old 04-02-2011, 07:47 PM   #17
blackbeaSSt
yeah i might have to do that. at least you won't be able to see the old crap when inside.....hopefully! it just pisses me off i had the windshield professionally replaced not too long ago and it didn't stick
