#226 |
Grandpa in the rustmobile...
Re: '72 Chevy SWB, Project Driver
I envy your future potential gas mileage..lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#227 | |
Has more rust than truck...
Thanks, I hope it is! I'm down to riding my motorcycle pretty much all the time now
![]() Quote:
Thanks, Hopefully its better than the 250 I took out. In that 100 miles I drove it, it used over a half tank ![]() I owe a thank you to everyone that assisted in my search for the correct motor mounts, I finally got something to work. If/when I do this again I'll use the 73+mounts with extensions welded to the cross member so the motor can be all the way back. The way I have it now is a bit far forward, but this is what came together and I might not even need to modify my drive shaft now. ![]() ![]() ![]() ![]() I picked up a trans cooler off of Craigslist tonight. ![]() |
#228 |
good times........yeah, I did have a question, i know you you got a heck of a deal on your motor and trans but did you look at the cost of a gen 1 smallblock rebuild and compare the two or was an ls swap part of the plan all along.
#229 |
I didn't do a cost comparison this time, but in the past I have built up a ol 350. By the time I had good parts (parts are the cheap part) and all the machine work. I had well over $2,000 in it and maybe only 300hp, horrible cold starting(in MN) with 9-11mpg. After owning a vehicle with a LS, I knew my small block days were over.
#230 |
just wondering i built a 383 stroker for my 95 gmc last year and after it was said and done i had about 3600 in it and it gets terrible mileage havent compared the cost of the two yet but if i could find a set up similar to what you have there really isn't a comparison especially if i can get a low mileage engine/trans combo anyways looking good can't wait to see it run got a lot of research to do.
#231 |
Green club
Excellent work with the mounts, great news
![]() I am running the same pump, works like a charm. I mounted mine right in front of the tank on the frame rail, I'm running the blazer tank as well. Very quiet too, when you turn the key all you hear is a low humm until the rails are pressurized and off you go. Sweet setup.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 03-29-2011 at 03:25 PM. |
#232 |
Installed power steering box, power steering pump, radiator and radiator hoses. Modified the power steering reservoir because it originally went above the hydroboost. Bent/flared a trans cooler line, still need to run the hoses to the aftermarket trans cooler. I also started researching how to mount up the hydroboost. When I pulled my master cylinder so I could get some good measurements I found my 1 year old master cylinder was leaking
![]() ![]() ![]() Still need to add a brace here. ![]() ![]() I had to modify my outer bumper bracket to get the box in there..... ![]() |
#233 |
looks great!!
whys the sig say 292 4l80e? is that what the 4.8 comes out to lol? im jealous!
#234 |
Restoration Virgin!
Nice to see this progress!!!....What are you gonna do about that top radiator hose?
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#235 | |
![]() Thanks! It might get trimmed a little, but it will look much better when I get E fans in there and tie it to them. |
#236 |
looking good , are those the o.e. manifolds or off something else its been awhile since i read that part of your thread. looks like your getting close to fireing it up.
#237 |
Thanks, The manifolds are stock Trail Blazer SS (LS2) manifolds. They are just set in there with 2 bolts right now to see how they fit. Honestly I could plug in the TAC and gas pedal and it would start and run IF I had my fuel hose ends. Which are back ordered until the 21st.
#238 |
Wow the 21st that sucks, don't you hate it when a couple of fittings are all that's holding you back.
#239 |
What was the hardest part of the swap so far at least (shucking out $ for parts doesnt count lol
#240 |
Coooool project! Kudos to you for making the harness work. Personally I dont think I would have the patience or ability. Nice work!
#241 | ||
![]() ![]() Quote:
TBSS manifolds bolted up, just had to trim about 1/2" off the drivers side trans "wing" I used the original bolts and gaskets....hope they don't leak. This on the other hand WILL leak so now I get to search for a drivers side flange. I think it happened when the guy pulled the motor out with a skid loader. ![]() Finally ran all the wiring in the cab, now to hook it up. ![]() Last edited by usmcchevy; 04-04-2011 at 10:23 PM. |
#242 |
Still Learning
Look like you are getting close. I like what you did to the motor perches. Did you consider using the newer style mounts like the 73 up trucks uses? I have a set and I'm hoping they will work without modifying. Keep the pics coming.
#243 |
subscribed
The TEAL GMC build thread is HERE 1972 GMC SWB 454 oval ports TH400 fastest 1/4 mile time so far 13.05 @ 104 If you think you have too much horsepower you obviously have a traction problem ! |
#244 |
Engine dipstick installed. Finished Trans cooler lines just need some hose clamps. One of the two hoses I ordered for the Power steering/hydro boost worked. I'm going to have to make the other as it needs a 11/16 inverted flare on one end and a 18mm O ring on the other.
I played around with trying to start it, didn't make it far. With the TAC hooked up the Throttle body makes a high pitched hum and doesn't respond to the gas pedal. The TAC didn't come with my motor, but has the right part number on it so tomorrow I need to check the TB wiring. |
#245 |
'67 C-10 LWB Driver
![]() Join Date: Dec 2010
great build! best of both worlds when you get her running!
'67 C-10 LWB - My Build Thread ![]() '67 C-20 LWB - My Donor/ Parts truck - SOLD! '92 GMC SAFARI VAN - My Parts Go Getter '06 KIA SPORTAGE EX - My Commuter "All of this crap better make a truck!" - my wife Sue. Proud U.S.M.C. Dad! |
#246 |
Thanks! Not much happening due to having corrective eye surgery (PRK) on Wednesday. I did give up on summit sending the hose ends because the delivery date got pushed back to May 24th. I called Jegs and they price matched Summit with their stuff and it will all be here tomorrow
![]() If you want to know anything about hydroboost he is the man! |
#247 |
Jegs stuff showed up today.
Hydroboost plate with rod cut off and new end threaded on. I will need to enlarge the hole in the fire wall to clear the nut that holds the hydroboost to the plate. ![]() Lokar trans dipstick installed. ![]() Put together my first teflon AN fitting. ![]() And a couple of the pump/filter/reg with all the adapters. ![]() ![]() Looks like I'll have some time to work on her this weekend......maybe we'll have fire ![]() |
#248 |
I cant wait for ya buddy!! AN lines look clean!!
#249 |
6>8 Plugless........
![]() Join Date: Sep 2007
Very nice job! I installed hydra boost on my vette and that was a huge step up compared to having to press down with your life to get stopped.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#250 |
Did that hydroboost come out of the van you got the motor from? And have you seen these http://67-72chevytrucks.com/vboard/s...d.php?t=347480 http://www.67-72chevytrucks.com/vboa...d.php?t=347484
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
