03-29-2011, 10:06 PM | #1 |
Lower Control arm frustration...
So i am working on this blazer of mine and discovered that the lower control arm was bent at some point (looks like it was curbed or a tow hook ripped into it). So far, i have purchased 3 different arms and had no luck (one was wrong balljoint size, one exact same damage and 3rd one rust and shaft threads stripped). I seem to have exhausted the local supply. Does someone sell these arms new/repop?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
03-30-2011, 01:25 AM | #2 |
Stalker Nate
Re: Lower Control arm frustration...
You know you should just switch it out to 3/4 suspension and take mine Problem solved. I haven't had a chance to check the size but you're probably right that the 3/4 arms are different than 1/2T.
Nate
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
03-30-2011, 05:54 PM | #3 |
Change the ball joint on the one with the wrong balljoint. I've done it more times than I can count.
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
03-30-2011, 06:02 PM | #4 |
I changed my arms to 73+
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
03-30-2011, 06:05 PM | #5 |
You can do that, but you have to change out the balljoint also. I have also put the '73 up drop spindles on the 72 down arms by putting 73 up balljoints on my old arms. I love these trucks, there's so many ways to make them work!
Rg
03-30-2011, 08:56 PM | #6 |
i specifically have 71-72 drop spindles. The 3/4 balljoint hole is larger diameter than the 1/2 ton.
