Woot.
What is a good first 4x4 ???
Hey y'all!
I am looking at getting a 4x4 truck to fool around with ![]() Thanks!!! Andrew
Clarkson 96 Chevy RCLB 4.3 2WD |
Fabricator
81-85 1ton, Dana 60 front corporate 14 rear, tranny doesn't matter it is going to be a th400 or sm465, transfer case will be a NP205 gear to gear. They came with 454's and also 350's. Absolutly one of the toughest trucks chevy ever drove off an assembly line. Hope this helps
84 C30 Chassis 60 & 14, 454/400/NP205 Retroing 98 X-tended Cab Built with the blood and sweat from the hands of a Chevy man. |
they started offering the K30 in 77 I think...it would be great, but sounds a bit overkill for what you want. people know what they are worth, and you can't usually find one for cheap. just stick to a 73 up K20, it will have a dana 44 up front instead of a 60. also may have a fulltime transfer case. or you could go to the ford side of things...I'm thinking 70's F-150 or F-250. both are pretty tough. also, an '86 up F-350 has a dana 60 frontend if you want beef...plus the option of a diesel. i'd personally hold out for an early 90's with a 7.3 (Powerstroke or non) diesel. Oh I forgot about the military K40 (1-1/4 ton) that Chevy made. I forget its technical name. it is basically a K30 but has a 6.2 diesel and a rear locker. there are plenty of other oddball vehicles that would be great to offroad. IH, Jeep, Ford, Dodge, and GM all made great 4x4's at one time or another. Also, people swear upon Toyota trucks and SUV's especially the older ones with solid front axles, altho i dont like them. good luck in your search
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Village Curmudgeon
All of the manufacturers have made good trucks. You really can't go wrong with any of them. But one of the things you mentioned should narrow it down to one truck.
If you want something you can get parts for any time and any place, you want a Chevy truck with a small block V-8. And the '73 and later is a good choice, because the 67-72 are becoming collectible, more expensive, and harder to find. Even though I'm a diehard Chevy fan, I would never say that Ford, Dodge, and the others don't build good trucks. They do. But nothing can hold a candle to Chevy when it comes to parts availability. You can see from my signature that I'm also an IH fan. Great trucks, tougher'n nails, and will last forever if you take care of them. But try to get parts on Sunday afternoon in Glasgow, Montana.
78 Chevy K30 duallie, 454, TH400 78 IH Scout II, 4X4, 345, 727TF 76 IH Scout II, 4X4, 345, 727TF 65 IH 1200C pickup, 4X4, 345, 4 spd 48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck) "Life is too short to drink cheap beer." Harry S. Truman ![]() |
user # 2756
![]() Join Date: Jun 2001
The 5/4 is the M1008, in military terms.
My first 4x4 was a 76 Scout II had very stout drivetrain (T-19 tranny/ dana 20 TC) dana 44s front and rear. 4" got me 33s on 10" wide rims. I put about $1500 into and drove it for a while. You can't beat parts availability with the GMs, I'd stay as early as possible and look for 3/4 ton and up (usually emissions requirements not as bad).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I know everyone likes the 3/4 ton and 1 tons, But 1/2 ton Chevys aren't bad either... 1/2 ton parts are typically cheaper and sometimes more readily avalible. However, If you go 1/2 ton, stay away from the 10 bolt rears if you can... I believe they switched to those in 77 or 78. I just picked up a 76 K5.... she's got a Dana 44 front, a 12 bolt rear, 350, THM350 and NP203... plenty beefy for the wheeling I do. Hell, I wheeled a stock S10 for years and it held up well to the abuse.
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
![]() Join Date: Feb 2001
The 12 bolt was around until the early 80's I believe. The late 70's and early 80's GM trucks are the way to go. Parts more handy and cheaper.
