#176 | |
SSN 706
Re: Daverods 52
#177 | |
Re: Daverods 52
That said, if you're running normal street tires and messing around like a normal driver, i wouldnt worry about it. If you're going to take it down the dragstrip on a regular basis, or if you're planning on putting drag radials or slicks on it... then Id start to worry about it. otherwise... its fine. you'll burn up your street tires in a cloud of smoke before it breaks. |
#178 |
SSN 706
Re: Daverods 52
Great thats all I want a big cloud of smoke. Hell, my frame will be on the ground anyway. It's not as if I'll be going anywhere.
#179 |
Re: Daverods 52
Unless you setup your air suspension and driveline angle for it, you probably dont want to try to do burnouts with the bags fully deflated.
#180 |
Daring to be Different
Re: Daverods 52
Your right Dude. A parallel 4 link would help minimise the pinion angle. But Dave doesn't care. He likes to burn up money anyway.
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#181 | |
SSN 706
Re: Daverods 52
#182 |
Member of the longbed union.
Re: Daverods 52
Just get a double u joint for 12* of change. Then let it rock and roll.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#183 |
SSN 706
Re: Daverods 52
Got my rear air kit for 125 off.
![]() Saving $$ not ![]() ![]() ![]() What you doing for bags/cups in the front Paul.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 03-31-2011 at 06:55 PM. |
#184 |
Re: Daverods 52
I bought some off a guy local. He said they are SD cups. And I got a set of DOM II's 2500 i'm gonna use. Most people say you dont get the lift that you big lift, but I'll just have to see.
They have them on sell right now for $185. cups, 2500 DOMII, line and some fittings. I was talking to Jason (SD) the other day, and he said that he doesn't like the bags on the outside of the frame like that. He said that they will twist, so just watch it. I'm still not sure how I'm gonna run mine. I may go bag behind the axle!
#185 |
SSN 706
Re: Daverods 52
20 minutes digging in the dirt at the junk yard and look what I found.
#186 | |
SSN 706
Re: Daverods 52
#187 |
Re: Daverods 52
Here is your kit installed on a truck so you know how it looks.
This is what I use for my background so I know what it looks like!
#188 |
Re: Daverods 52
You have to remember on the C10's the bars can be ran on the outside of the frame. On the S10 they cant. So you will get a little bit of twisting!
#189 |
SSN 706
Re: Daverods 52
My first powder coat job. Should have maybe put it on a little thicker. Next time.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-01-2011 at 11:55 PM. |
#190 | |
SSN 706
Re: Daverods 52
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-02-2011 at 12:07 AM. |
#191 |
![]() Join Date: Mar 2008
Re: Daverods 52
I think the twist he is talking about is on the link bushings because the bag mounts are not centered over the bar. With them hangin on the side of the link bar it puts a twist on the bushings and may wear out faster.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#192 |
SSN 706
Re: Daverods 52
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-02-2011 at 05:40 PM. |
#193 |
SSN 706
Re: Daverods 52
Sold my old frame for 150. Parts for parts. Still have the old transmission.
#194 | |
SSN 706
Re: Daverods 52
![]() Quote:
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-02-2011 at 05:36 PM. |
#195 |
Re: Daverods 52
Shocks aren't load baring. With urethane bushings the arms should be OK. Not the best setup, but is very popular.
#196 |
SSN 706
Re: Daverods 52
Makes me feel better. I was'nt looking for the best anyway. More like fast,easy and cheap.
#197 |
SSN 706
Re: Daverods 52
Wire whipped my frame painted it . Sand blasted my lower arms pressed some new ball joints in and painted them. Ordered some bags for the front and some cups. Rented the press for Auto zone pressed them myself. Did'nt know they rented the press.
#198 |
Re: Daverods 52
The twist that I'm talking about is going to be at the bushings. Because the bags are offset on the bar. You know the bars will mount under the frame with the bags on the outside. So that will give you a little bit of twist.
No I dont need a trans. Just so you know you will have to cut the spring pockets in the front for the bags to sit in and not rub. Once you get your cups and bags check it out.
#199 |
SSN 706
Re: Daverods 52
The cups weld in? I was kinda wondering how that worked. Does this mean I'll have to repaint?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 04-04-2011 at 11:17 PM. |
#200 |
Re: Daverods 52
You can buy weld in cups. or you can get bolt in like I have. Most people use the bolt in, no holes to drill, they go in the factory holes for the shocks.
