03-30-2011, 03:29 PM | #1 |
6 lug to 5 lug rear axle swap
can i put 1971 5 lug rear axles in to my 1965 chevy c-10? i see on napaonline.com they have an axle set with bearings and seals for $174.00. all the conversion kits i've seen are for 1963-1970. 1963-64 need an axle gear set as well. if the conversion works for a 1970, then why can't you just put a 1971 axles in to a 1965 rearend? any advice?
Last edited by unclemnstr1965; 03-30-2011 at 03:43 PM. Reason: entered wrong year |
03-30-2011, 03:43 PM | #2 |
Re: 6 lug to 5 lug rear axle swap
I was wondering this a while back and if memory serves me correctly(don't quote me) #1 the reason they say you need side gears is because early models ran 17 spline spider gears and #2 I believe the 71-2 axles (5lug) are wider than the 64-5-6 model rears. I know also 68-69 gmc axles are wider than 64-5-6. You might check on the "70" 5 lug axles I didn't know they had them that year.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
03-30-2011, 03:55 PM | #3 |
you're probably right... i thought 5 lug came out in 1967 for some reason. guess because of the body change. thanks.
03-30-2011, 04:13 PM | #4 |
5 lug started in '71 as far as I know.
03-30-2011, 04:43 PM | #5 |
CPP has them.
1960-64 Complete 5-lug Rear Axle Conversion, 30-3/4", kit:: http://www.classicperform.com/Store/...k/6364RACK.htm 1965-69 Complete 5-lug Rear Axle Conversion, 30-3/4",kit: http://www.classicperform.com/Store/...k/6569RACK.htm
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
03-30-2011, 09:35 PM | #7 |
i just had my original 65 axles redrilled to 5 lug,drums too, just cost 80 bucks for it all. poor mans way out .
03-30-2011, 10:25 PM | #8 |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-31-2011, 12:28 AM | #9 |
Junior Member
71 axles are longer than your 65 I do believe
I had my 67 axles redrilled & the center turned down for $50. using 71 & up 5 lug drums
frontstreetcycle on Instagram Last edited by scrapmetalart; 03-31-2011 at 12:30 AM. |
03-31-2011, 12:50 AM | #10 |
I'm guessing the 70 went to a 3/4" longer axles but kept the 6 lug. In 71 they went to 5 lug with the longer axles. CPP lists the 70 axles at 31.5" as compared to the 60-66 axles at 30.75".
03-31-2011, 12:59 AM | #11 |
60-66 Nut
1970 was the transition year for the width of the rear differentials, Typically the early '70 rear differentials were the narrower version as the prevoius years. The late '70 differentials were 1.5" wider overall (.750 per side) like the '71 and up differentials. That is why you can't use a '71 and up axles in the '63-early '70 differential housing.
03-31-2011, 09:41 AM | #12 |
why dont you just switch the whole housing with axles ? that's what i did on my 63. I took a rear end out of a 72 1/2 ton it bolted right up.
03-31-2011, 09:55 AM | #13 |
04-01-2011, 07:55 AM | #14 | |
UCA63
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
04-01-2011, 08:35 AM | #15 |
Why not run the 6 lug?
Posted via Mobile Device |
04-01-2011, 08:42 AM | #16 |
04-01-2011, 11:44 AM | #17 | |
Captainfab, I have a '66 C10 rear. If I have the axles redrilled, could I use one of your disc conversions? I would like to use the Camaro caliper with built in e-brake.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-01-2011, 11:49 PM | #18 |
60-66 Nut
Yes you can use the Camaro caliper brackets with redrilled axles, but you would need to have the center register turned down to about 3.06" You know I do have the 6 lug rear disc brackets that utilize the Camaro calipers with a 13" rotor. The drawback to those is that you will need a 16" or bigger wheel.
04-09-2014, 01:13 PM | #19 |
I have a 70 and mines a 6 lug Ll around
02-18-2015, 07:27 PM | #20 |
Digging up an old thread here but I have some axles I'm gonna re drill to 5 lug but just wanna make sure they're the right length. I had bought a 12 bolt a while back and used the carrier and pinion so I could get the gears I wanted. I used my old axles and ended up with an extra set. They measure 30 3/4 from the back of the flange to the end of the splines.
BaBaBooey BaBaBooey GO SPURS GO!!! |
02-18-2015, 09:35 PM | #21 |
Anybody?
02-18-2015, 10:31 PM | #22 |
I guess if you are just using yours as a daily driver, not as a work truck, not to say that there is anything wrong with that, mine has 8 lugs
02-18-2015, 10:49 PM | #23 | |
?? ^^^Doesn't really make sense, or answer my question, or help even. My front is 5 lug since I put disc brakes and I'd like to match the rear to the front so I can run spider caps instead of baby moons. It's a half ton too
02-19-2015, 12:36 AM | #24 |
60-66 Nut
Typically the '63 to early '70 12 bolt axles measure 30.5". So I would say your 30.75" axles are correct, just a little variance in the measuring method.
02-19-2015, 02:38 AM | #25 |
Hi, I just put a mid 80s suburban 308 rear end in my 70 gmc. More info in my build thread on it, I took the 5 lug axles out of it and put the stock 70 gmc 6 lug axles right in there, was a really fast easy swap. My buddy did the exaxt same thing 6 years ago with is 67 chev, still working great,
Have a good week
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438 70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983 76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612 79 GMC 3500 Fleetside LB 454/400 90 Suburban Silverado 4x4 350/700R4 97 1500 Cheyenne Short Fleet 350/5sp |
