#26 |
![]() Join Date: Apr 2007
Re: "The Northbay G Machine" 1969 GMC shorty build
Cracked a piston in the 010 350 so time to rebuild it. Slapped in the old 307 and decided to try some ceramic mid length Chevelle headers I picked up off the bay for $150.
![]() Time to use the mandrel bent 2.5" exhaust tubing, summit x pipe. and 40 series flows. also picked up a set of motor perches from cpp that I thought would help make some more room for the headers but ended up modifying them too ![]() I ran into problems with the z bar not having room to be mounted to the stock location and having real tight clearances between the header and oil filter. I modified the hell out of the original Z bar. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() here is a shoot of how much room i had to work with. ![]() ![]() Had to move my e brake cable slightly to clear the x pipe. worked great. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-01-2011 at 02:37 AM. |
#27 |
Thanks bro
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
#28 |
Got tired of looking at 3 different colors so decided to put a temp coat of satin black on her.
sorry this is the only pic i have :P ![]() Finally decided to fix my bedside. Found a long bed side at pick-n-pull and cut out what I needed. just cut trace and paste! if only it were that cut and dry lol. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-01-2011 at 02:26 AM. |
#29 |
Found that TPI system I was looking for. Had to buy the whole car to get it
![]() ![]() more pics to come on this. ![]() ![]() ![]()
#30 |
Yes, Santa Rosa, Ca. Lived in Bennett Valley and went to Montgomery High School.
70 CST, 6.0/ 4L80E in the works. *Custom harness by 68 Short Step* |
#31 |
Im also in the valley! do you know Bobby Wilson? He lives over here too? He is about our age also he goes by Wilson on here.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-02-2011 at 04:56 AM. |
#32 |
Nice body work on the bed,looking good
#33 |
Thanks! wish i would have took more pictures after that, I just got rushed to finish the panel and spaced it.
#34 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Great looking truck..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#35 |
Picked up this 65 for my frame graft project.
#36 |
Started the 2nd gen F body graft, this is where I made my first cuts and how It progressed.
![]() ![]() ![]() ![]() ![]() Some portion of the sub frame's outer edge will be removed. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() here it is cut and slid into the frame. I still need to cut the truck frame more. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Moved the frame inside a tarp enclosure to get out of the sun ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Cleaning up the sub frame and welding it up. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() hit the inside of the frame up with por 15 ![]() ![]() ![]() ![]() ![]() finished welding it up and decided to spray some oil based Rustolium on there just to protect the metal I wont be keeping the blue color but its what i had on hand. ![]() ![]() ![]() ![]()
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-16-2011 at 12:02 PM. |
#37 |
Getting ready to box it in in preparation to make the x frame and 3 link brace.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-16-2011 at 12:10 PM. |
#38 |
67cheby
![]() Join Date: Sep 2008
That has got to be the nicest subframe graft i have ever seen ....nice work
#39 |
Thanks brother,
![]() Cant wait to get it rolling, and surprise some people at the local auto x events ![]() Its not too common to see trucks carving corners and thats one of the cool things about this build. This frame should be quite stiff once completed with it boxed and x framed. The rear section of the frame will also have the added benefit of a square structure over it (the bed ) to furthermore resist twisting. I will show you guys when I get to that point. Ive decided to go with a 3 link setup in the rear but I will continue to use the leaf system until I get to that point.
#40 |
PROJECT 7DEUCE
Good job on the graft..
#41 |
NICE!!!!! job on the graft,keep pictures coming of your progress
#42 |
That is one gorgeous subframe graft! I really like the g-machine truck concept your rolling with. Makes me wanna scrap my air bag plans and do the same thing! I will be following this build till your hanging corners! Keep da pics coming!
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! ![]() 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
#43 | |
#44 | |
i will stop by soon. what hours/days are you working now?
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
#45 |
Little update. Ive done quite a bit on the truck since I last posted. Ive been real busy with things and having to move my shop and my home set things back. Since I last posted, Ive put together a stout little 500 hp pump gas 460 BBC, Installed a built TH400 and and rebuilt my 12 bolt with 4.11 gears. The Truck has been lowered another inch in the back.
The truck currently runs low 12's on street tires with reserved throttle movement off the line. best 1/4 time 12.1 @111. The truck should be in the mid to 11's with traction. Hopefully the Tubed frame with graft Ive been working on with the 18.5 mickeys will help there. I still have not finished the Frame I was working on but plan to start on it again this month. I will upload some pictures of my progress over the last 2 years. Looking forward to getting back on this!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-27-2014 at 01:29 PM. |
#46 |
#47 |
Back on the frame Guys! Just made these simple adjustable stands out of some scaffolding legs. Now its time to finish the rear for the phaties!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-29-2014 at 11:39 PM. |
#48 |
#49 |
#50 |
I'm defiantly going to tune in on your build. Your steps to your frame build is really nice. I've been thinking about putting a sub frame on my frame, but I think I may run into some road blocks. Not real sure yet.
